Home > General > Range Rover Gone Bang
Page 4 of 4 <1234
oxford-boy
United Kingdom 2005 Range Rover Sport TDV6 HSE Arctic Frost
Are you using Warranty Direct for this job? 2005 Range Rover Sport TDV6 HSE in Artic Frost. 20" 2010 HST Alloys, sidesteps, Hawke tips, plus minor bits and bobs along with a remap. Four spike spiders ready for the Alps again now tucked up in their garage boxes...
Post #381731 Mon Apr 29 2013 1:51pm
Disco_Mikey
Dragon Engines, another "re-conditioning" specialist
Post #381742 Mon Apr 29 2013 3:14pm
simple1
Who do LR use. As its obvious that it is an out of house affair? 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #381753 Mon Apr 29 2013 6:25pm
Bodsy
Site Sponsor
At least the warranty co have agreed to foot the bill Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #381754 Mon Apr 29 2013 6:29pm
drdelrrs
I just wonder - if, - in the future, there should an engine problem would Warranty Direct have indigestion because the car's history showed that it had not been repaired by Land Rover !
Post #381759 Mon Apr 29 2013 7:03pm
simple1
Wouldn't think so as this appears to be their approved repairer 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #381791 Tue Apr 30 2013 7:59am
SRE
Spain
Bodsy wrote:
SRE wrote:
Beg's the question, is it possible to fit the latest oil pump casing to pre 09 cars.
Yes you can to 07 and 08 engines. Although it tales about 7-1/2 hours, so not a cheap dealer fix.....
I am going to book my car in for a new oil pump, is there anything else that I need to change whilst the front of the car is stripped down???
It had new cam belt 12 months ago. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #382273 Mon May 06 2013 12:46pm
Bodsy
Site Sponsor
You could change the water pump which you need to remove the timing belt to do anyway. Istr water pump is about £70 Thumbs Up Bodsys Brake Bible
See it HERE
Post #382274 Mon May 06 2013 12:54pm
simple1
Do no harm to replace the belt again either. Doesn't do them any good being under tension then removed and refitted. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #382275 Mon May 06 2013 1:14pm
SRE
Spain
Prior to booking my car in for the updated oil pump, can I just re confirm that the pump I need is the one fitted to the 3 litre engine - the latest version being LR013487.
Also as the car has only covered 35k, is it worth changing the water pump? In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #382500 Wed May 08 2013 1:14pm
Bodsy
Site Sponsor
there is one for pre 06A99999 1348651
then 07A00001 on it superseeds 3 times to finally end up at LR013487
LR002465-LR007131-LR007798-LR013487
low mileage, so probably not worth changing the water pump. i did, but that was 100k so seemed sensible. Thumbs Up Bodsys Brake Bible
See it HERE
Post #382503 Wed May 08 2013 1:25pm
SRE
Spain
Latest type oil pump now fitted by main dealer €400 all in Thumbs Up
Post #383785 Wed May 22 2013 2:09pm
Bodsy
Site Sponsor
not a bad price at all Thumbs Up Bodsys Brake Bible
See it HERE
Post #383790 Wed May 22 2013 2:29pm
JasM
Scotland 2012 Range Rover Sport SDV6 HSE Orkney Grey
Did you get any other bits changed at the same time? 2014 L405 SDV8 RR Autobiography Cool
2012 RRS SDV6 HSE -Orkney Grey with A/B bodykit - Now Gone Sad
2007 RRS TDV6 HSE - Zermatt Silver - Gone
Post #383813 Wed May 22 2013 5:04pm
Page 4 of 4 <1234
