![]() | Home > Technical > FBH Remote |
pko Member Since: 31 Jul 2011 Location: norfolk Posts: 193 ![]() ![]() ![]() |
Would this work straight out of the box on my 2013 hse black, which has timed heating on the menu, or will it need to be programmed in by the dealer? many thanks p |
wiggs Member Since: 27 Apr 2007 Location: Manchester Posts: 99 ![]() ![]() |
No ... You would still need to fit the receiver and antenna ... Then get it enabled Bluetooth Exchange www.bluetoothexchange.co.uk |
thanks for prompt reply, Wiggs, cheers,p |
muddywheels Milk Float Man Member Since: 01 Jul 2010 Location: East Riding of Yorkshire Posts: 5644 ![]() ![]() |
Found this - looks about right |
You need the remote (as long as they can be retuned then there shouldn't be an issue eg faulty) you can tune them. You need the software updating for remote then you need the box and aerial Mike
paulL Member Since: 20 Dec 2005 Location: Barcelona Posts: 263 ![]() ![]() ![]() |
Ok guys.
its all in the thread and a search will bring up loads of others...this topic is done to death every winter!! Mike
rigsby Member Since: 20 Apr 2012 Location: Portsmouth Posts: 879 ![]() ![]() |
Parts are approx. £200, enabled for £50 20 mins to fit ![]() 2012 3.0 SDV6 Luxury gone, but a great motor |
Ok so final question. I don't need to configure the satnav screen or anything like that for just the remote operation of the FBH? 2013 RRS SDV6 Autobiography Fuji White
yes you do Mike
As MSE says... yes you do MY16 AUTOBIOGRAPHY Indus silver with some toys
Thanks... 2013 RRS SDV6 Autobiography Fuji White
harrygh60 Member Since: 16 Nov 2011 Location: London Posts: 395 ![]() ![]() ![]() |
Hi Rigsby, Did you get your Remote up and running?. As i said before i got my software downloaded for £50 Bought my Reciever, and Aerial from Yeovil £156 +£6 postage, Fob from Ebay £19.95. Followed a thread on here to fit and pair the fob. Works perfectly ![]() ![]() |
Hi Harry, all works perfectly on the screen or from the remote. Just tucked the aerial into the headlining without sticking it down but works fine. Took 20-25 minutes so all good thanks mate. MY16 AUTOBIOGRAPHY Indus silver with some toys
