![]() | Home > Technical > Revving, hunting, shudder under load RRS 2005 |
jonpop Member Since: 16 Mar 2010 Location: norwich Posts: 7 ![]() ![]() ![]() |
I have the same problem except mine only does it on tickover somtimes.
ELD70 Member Since: 20 Jan 2009 Location: UK Posts: 163 ![]() ![]() |
Automatic gearbox flush and fluid change? |
paulmc Member Since: 07 Sep 2010 Location: Aberdeenshire Posts: 25 ![]() ![]() |
Sounds like a Torque converter problem. Cayenne Turbo "S" 521bhp Standard |
As ELD stated, it's a classic sign of the autobox fluid deteriorating and needing changing. You can get it flushed by 4-tech or double flushed by your dealer at an extortionate price!!
At a steady load / speed the torque converter is trying to engage it's lock up mechanism but in your case it seems like it is failing to engage. As said a change of fluid and a flush may well fix the problem. Fingers crossed |
GoofyP Member Since: 27 Nov 2019 Location: West Lancashire Posts: 3 ![]() ![]() ![]() |
Hi Everyone.
Stand Easy Member Since: 10 Aug 2016 Location: Manchester Posts: 126 ![]() ![]() ![]() |
K Motors in Leyland are decent IME |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 957 ![]() ![]() ![]() |
Had mine done at Quattro autocare in York,, cost about £270 with 2 tubes of Dr tranny added. 2010 RRS, TDV8
Thanks guys.
It's easy enough to do yourself. I did mine in about 30 mins. Full flush, using a pressure sprayer on my driveway and a bit of hosepipe.
