Home > Technical > Revving, hunting, shudder under load RRS 2005
jamster
2005 Range Rover Sport TDV6 HSE Java Black
Hello,
I've got a shuddering problem at low revs only when the car is moving and when a steady speed is beig maintained. The only way to get rid of it is floor it. Its not tyre related. Its like the clutch is slipping and its thinking about changing gear but doesnt.
At a steady speed the revs alternate up and down around 300-400rpm each side of where ever they are in the range. So at 2500rpm the needle would travel to 2800 then to 2200 almost like the engine is hunting. Again if I floor it the problem goes away.
Its worse going up a hill and doesnt happen at high revs.
Any ideas?
Thanks,
Jamie
Post #275941 Mon Sep 13 2010 6:59pm
jonpop
United Kingdom 2006 Range Rover Sport TDV6 HSE Zermatt Silver
I have the same problem except mine only does it on tickover somtimes.
Any help with this also, warrenty runs out soon
Post #276121 Thu Sep 16 2010 3:36pm
ELD70
Automatic gearbox flush and fluid change?
Post #276126 Thu Sep 16 2010 4:16pm
paulmc
Scotland
Sounds like a Torque converter problem. Cayenne Turbo "S" 521bhp Standard Smile
www.bmw535d.co.uk
Post #276131 Thu Sep 16 2010 6:31pm
Bodsy
Site Sponsor
As ELD stated, it's a classic sign of the autobox fluid deteriorating and needing changing. You can get it flushed by 4-tech or double flushed by your dealer at an extortionate price!!
Will almost certainly fix the problem. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #276134 Thu Sep 16 2010 8:41pm
paulmc
Scotland
At a steady load / speed the torque converter is trying to engage it's lock up mechanism but in your case it seems like it is failing to engage. As said a change of fluid and a flush may well fix the problem. Fingers crossed Wink Cayenne Turbo "S" 521bhp Standard Smile
www.bmw535d.co.uk
Post #276135 Thu Sep 16 2010 8:52pm
GoofyP
United Kingdom 2008 Range Rover Sport TDV6 SE Java Black
Hi Everyone.
I know this is an old thread, but I am having the same problem with my 102k 2008 SE.
To this end how difficult a job is it for the home mechanic, or does anyone know where I could get it done in the Preston area without it costing £1000's.
Thanks in advance gang
 A Land Rover is for Life, not just Christmas!
Post #593502 Sun Jan 19 2020 10:30am
Stand Easy
K Motors in Leyland are decent IME
Post #593505 Sun Jan 19 2020 12:04pm
gogsy1956
Had mine done at Quattro autocare in York,, cost about £270 with 2 tubes of Dr tranny added. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #593514 Sun Jan 19 2020 5:25pm
GoofyP
Thanks guys.
I will give them a call. A Land Rover is for Life, not just Christmas!
Post #593551 Mon Jan 20 2020 8:45pm
knwatkins
It's easy enough to do yourself. I did mine in about 30 mins. Full flush, using a pressure sprayer on my driveway and a bit of hosepipe.
Mannol AG55 is a well respected fluid for the 6 speed ZF 6HP26 gearbox. The cheapest place I found was buying directly from Germany.
20 litres for 63 Euros: https://www.motor-oel-guenstig.de/schmiers...uessigkeit
12 litres is usually enough, but I pushed the full 20 litres through mine.
As yours is a 2008, you will have a different fluid cooler to me, but the principle is the same.
Have a look at the Filo method here for more info:
https://www.disco3.co.uk/forum/topic55010.html Kev
Post #593552 Mon Jan 20 2020 9:06pm
