![]() | Home > Technical > Revving, hunting, shudder under load RRS 2005 |
| jonpop Member Since: 16 Mar 2010 Location: norwich Posts: 7
I have the same problem except mine only does it on tickover somtimes.
| ELD70 Member Since: 19 Jan 2009 Location: UK Posts: 163
Automatic gearbox flush and fluid change? |
| paulmc Member Since: 07 Sep 2010 Location: Aberdeenshire Posts: 25
Sounds like a Torque converter problem. Cayenne Turbo "S" 521bhp Standard |
As ELD stated, it's a classic sign of the autobox fluid deteriorating and needing changing. You can get it flushed by 4-tech or double flushed by your dealer at an extortionate price!!
At a steady load / speed the torque converter is trying to engage it's lock up mechanism but in your case it seems like it is failing to engage. As said a change of fluid and a flush may well fix the problem. Fingers crossed |
| GoofyP Member Since: 27 Nov 2019 Location: West Lancashire Posts: 3
Hi Everyone.
| Stand Easy Member Since: 10 Aug 2016 Location: Manchester Posts: 126
K Motors in Leyland are decent IME |
| gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 961
Had mine done at Quattro autocare in York,, cost about £270 with 2 tubes of Dr tranny added. 2010 RRS, TDV8
Thanks guys.
| knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139
It's easy enough to do yourself. I did mine in about 30 mins. Full flush, using a pressure sprayer on my driveway and a bit of hosepipe.
| All times are GMT |
