Home > Technical > clicking noise from rear wheel
2nd Rower
Australia 2008 Range Rover Sport TDV6 HSE Chawton White
Very Annoyed wrote:
2nd Rower wrote:
I have exactly this. When I lower the car to access height to enter multi storey car pak and then leave it in access height I notice the clicking from the front right wheel each time I turn left as I drive up into the car park. Am going to get it looked at next time its in.
That's normal.
Really - what its another 'design feature' of the car?!
Post #199614 Sun Dec 14 2008 8:37am
Murdered out
United States 2008 Range Rover Sport 4.4 V8 HSE Java Black
Ok strike two, the brakes were fine, they cleaned up everything and couldnt find anything wrong. However when they tested to see the noise the vehicle was in offroad mode so there was no click! as soon as i lowered my vehicle and drove away it was clicking again Evil or Very Mad I immediatley had the service manger check it out as i rolled slowly. He thought it was my wheel (they're two piece) and that maybe the nuts that attach the two pieces of the wheel were lose. So I torqued them all, and still its clicking. The noise sounds like a a piece of metal is in my a bicycle spokes and just is annoying as hell. it seems like it clicks every half turn. Is there any ball bearings in the rear differential thing that spins that wheel? (sorry for my expert terminology) I'm thinking it is that or the suspension.
the noise coud be a clicking or a poping, or maybe a loud tapping. very similiar to that click that comes from the suspension when you raise it too offroad, but slightly loader. does anyone know what that "normal" clicking is from and why? maybe thats messed up.
Post #200792 Thu Dec 18 2008 8:39pm
rrsjo
My logic and opinion:
Based on what you say has been checked and eliminated already, if the clicking is only heard at regular points of the wheels rotation AND only in some suspension heights, then my conclusion is that the problem is likely to emanate from the universal joint on the drive shaft. Gone - 2008 TDV8, Stornoway Grey, ebony, zabrano trim, TV, Tasmods, mudflaps.
Post #200846 Fri Dec 19 2008 10:22am
Which is nearly what I said at the beginning of this post! All hail VA! Thumbs Up 2005 Zambezi TDV6 - Gone but not forgotten
Post #200850 Fri Dec 19 2008 10:31am
Do you think that premature wear on suspension components/joints/driveshafts can be attributable to putting bigger than recommended wheels on i.e. 21"+?
If so, you may have a fight on your hands with the dealer if your RRS is still in warranty (I know US warranties are different to UK) Runner up - 2009 Best Avatar Award Sad
Post #200866 Fri Dec 19 2008 11:45am
rrsjo
Needs a new univeral joint, "which is nearly what VA said" Bow down Rolling with laughter Gone - 2008 TDV8, Stornoway Grey, ebony, zabrano trim, TV, Tasmods, mudflaps.
Post #200948 Fri Dec 19 2008 5:03pm
Murdered out
wheel size would not make any issues with a suspension. my overall diameter is nearly the same size as the oem wheels/tires. yes my wheels are larger but my tires are smaller.
my dealer is very cool, they love, they would cover my ass even if it wasnt under warranty. I've never had t pay for anything, not even brakes. which in the US they make u pay for usually.
Post #200996 Fri Dec 19 2008 10:45pm
Bobby
http://www.rrsport.co.uk/gallery/albums/us...sembly.pdf Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #201030 Sat Dec 20 2008 10:24am
rrsjo
Bobby wrote:
http://www.rrsport.co.uk/gallery/albums/userpics/10024/Rear%20Drive%20Shaft%20Assembly.pdf
There you are courtesy of Bobby - outer CV Joint defective. Remedy under warranty - replace Drive Shaft. Gone - 2008 TDV8, Stornoway Grey, ebony, zabrano trim, TV, Tasmods, mudflaps.
Post #201106 Sat Dec 20 2008 5:30pm
Murdered out
sweet guys, thanks for the help. is there a TSP on this or anything i can bring into them to expedite my service. so they would have to replace the entire drive shaft for that one faulty section?
Post #201115 Sat Dec 20 2008 7:29pm
rrsjo
If the car was out of warranty I would want the CV joint replaced on its own, but Land Rover probably buy the Drive Shaft in as a complete unit and therefore will just send it back to their supplier as a reject and a credit. As such your dealer is likely to replace the appropriate complete Drive Shaft unit. Gone - 2008 TDV8, Stornoway Grey, ebony, zabrano trim, TV, Tasmods, mudflaps.
Post #201217 Sun Dec 21 2008 7:57pm
ZXA
Just noticed my RRS has the same problem about the noise from back wheel.
Murdered Out have you solve the problem yet?
Post #287394 Sun Jan 30 2011 2:42am
jig
2011 Range Rover Sport 3.0 TDV6 Autobiography Orkney Grey
any update on this issue? I think my car is making the same noise all beit quite loud with some screeching...
Post #603115 Mon Aug 10 2020 10:07pm
