| RRSPORT.CO.UK | ||
|  | Home > Technical > clicking noise from rear wheel |
| 2nd Rower Member Since: 12 Nov 2007 Location: Upside Down Posts: 1382      |
 Really - what its another 'design feature' of the car?! | ||
|  Sun Dec 14 2008 7:37am |
| rrsjo Member Since: 28 Nov 2006 Location: North Cambs Posts: 551      | My logic and opinion:
|  Fri Dec 19 2008 9:22am |
| Very Annoyed Site Moderator Member Since: 23 Aug 2005 Location: bat-wielding monkey-spanking tough-love zero-tolerance Euro-sceptic moderator - So just watch it! Posts: 19459    | Which is nearly what I said at the beginning of this post!  All hail VA!  | ||
|  Fri Dec 19 2008 9:31am |
| Supertrotter Member Since: 10 Mar 2006 Location: Brrrr.... guess where :o( Posts: 9905    | Do you think that premature wear on suspension components/joints/driveshafts can be attributable to putting bigger than recommended wheels on i.e. 21"+?
|  Fri Dec 19 2008 10:45am |
 Needs a new univeral joint, "which is nearly what VA said"    Gone - 2008 TDV8,  Stornoway Grey, ebony, zabrano trim, TV, Tasmods, mudflaps. | ||
|  Fri Dec 19 2008 4:03pm |
| Murdered out Member Since: 08 Feb 2008 Location: Arizona Posts: 324      | wheel size would not make any issues with a suspension. my overall diameter is nearly the same size as the oem wheels/tires. yes my wheels are larger but my tires are smaller.
|  Fri Dec 19 2008 9:45pm |
| Bobby Member Since: 07 Jun 2005 Location: Kuala Lumpur Posts: 3781      | http://www.rrsport.co.uk/gallery/albums/us...sembly.pdf Malaysia Boleh!
|  Sat Dec 20 2008 9:24am |
 There you are courtesy of Bobby - outer CV Joint defective. Remedy under warranty - replace Drive Shaft. Gone - 2008 TDV8, Stornoway Grey, ebony, zabrano trim, TV, Tasmods, mudflaps. | ||
|  Sat Dec 20 2008 4:30pm |
| Murdered out Member Since: 08 Feb 2008 Location: Arizona Posts: 324      | sweet guys, thanks for the help. is there a TSP on this or anything i can bring into them to expedite my service. so they would have to replace the entire drive shaft for that one faulty section?  | ||
|  Sat Dec 20 2008 6:29pm |
 If the car was out of warranty I would want the CV joint replaced on its own, but Land Rover probably buy the Drive Shaft in as a complete unit and therefore will just send it back to their supplier as a reject and a credit. As such your dealer is likely to replace the appropriate complete Drive Shaft unit. Gone - 2008 TDV8, Stornoway Grey, ebony, zabrano trim, TV, Tasmods, mudflaps. | ||
|  Sun Dec 21 2008 6:57pm |
| ZXA Member Since: 14 Nov 2010 Location: London Posts: 3    | Just noticed my RRS has the same problem about the noise from back wheel.
|  Sun Jan 30 2011 1:42am |
| jig Member Since: 14 Jan 2018 Location: London Posts: 49    | any update on this issue? I think my car is making the same noise all beit quite loud with some screeching... | ||
|  Mon Aug 10 2020 9:07pm |
| Posting Rules
 I immediatley had the service manger check it out as i rolled slowly. He thought it was my wheel (they're two piece) and that maybe the nuts that attach the two pieces of the wheel were lose. So I torqued them all, and still its clicking. The noise sounds like a a piece of metal is in my a bicycle spokes and just is annoying as hell. it seems like it clicks every half turn. Is there any ball bearings in the rear differential thing that spins that wheel? (sorry for my expert terminology) I'm thinking it is that or the suspension.
