![]() | Home > Technical > clicking noise from rear wheel |
| 2nd Rower Member Since: 12 Nov 2007 Location: Upside Down Posts: 1382
Really - what its another 'design feature' of the car?! |
| rrsjo Member Since: 28 Nov 2006 Location: North Cambs Posts: 551
My logic and opinion:
Which is nearly what I said at the beginning of this post! All hail VA! |
| Supertrotter Member Since: 10 Mar 2006 Location: Brrrr.... guess where :o( Posts: 9905
Do you think that premature wear on suspension components/joints/driveshafts can be attributable to putting bigger than recommended wheels on i.e. 21"+?
Needs a new univeral joint, "which is nearly what VA said" |
| Murdered out Member Since: 08 Feb 2008 Location: Arizona Posts: 324
wheel size would not make any issues with a suspension. my overall diameter is nearly the same size as the oem wheels/tires. yes my wheels are larger but my tires are smaller.
| Bobby Member Since: 07 Jun 2005 Location: Kuala Lumpur Posts: 3781
http://www.rrsport.co.uk/gallery/albums/us...sembly.pdf Malaysia Boleh!
There you are courtesy of Bobby - outer CV Joint defective. Remedy under warranty - replace Drive Shaft. Gone - 2008 TDV8, Stornoway Grey, ebony, zabrano trim, TV, Tasmods, mudflaps. |
sweet guys, thanks for the help. is there a TSP on this or anything i can bring into them to expedite my service. so they would have to replace the entire drive shaft for that one faulty section? |
If the car was out of warranty I would want the CV joint replaced on its own, but Land Rover probably buy the Drive Shaft in as a complete unit and therefore will just send it back to their supplier as a reject and a credit. As such your dealer is likely to replace the appropriate complete Drive Shaft unit. Gone - 2008 TDV8, Stornoway Grey, ebony, zabrano trim, TV, Tasmods, mudflaps. |
| ZXA Member Since: 14 Nov 2010 Location: London Posts: 3
Just noticed my RRS has the same problem about the noise from back wheel.
| jig Member Since: 14 Jan 2018 Location: London Posts: 49
any update on this issue? I think my car is making the same noise all beit quite loud with some screeching... |
| All times are GMT |
