Home > Technical > air con fan speed
tastech
Australia 2008 Range Rover Sport TDV6 SE Rimini Red
air con fan speed
Hi has anyone experienced this?
I find the air con after period time on auto, i switch to manual and face level vents (cause the auto is not blowing enough air in)...but i dont seem to be getting full power coming out of the vents even at full speed...
Dealer said they recalibrated the a/c fans...but i find that it happened again after the visit to dealer...
I happened by accident on some sort of fix, by dialing the fan speed back to zero and then back up...
and it then seems to blow at the right speed...
is this normal behaviour??
cheers Toyota Corolla...Sad((((
formerly: RRS TdV6 Rimini Red, Alapaca, Sat Nav, Prem Ice, Hybrid TV, Cooler, FPS, Tow pack, roof mounted lighthouse
Post #170761 Tue May 27 2008 1:13pm
Check you havn't got the system in auto mode (When the 2 lights are on on the dial.) 2005 Zambezi TDV6 - Gone but not forgotten
Post #170762 Tue May 27 2008 1:38pm
Jonny Fresh
A/C.....what's that?
Not much need for it in rainy Manchester Big Cry
Post #170763 Tue May 27 2008 1:39pm
tastech
HI VA
Yeah full manual both lights off...i have selected about the 12 or 1 oclock position and middle (face level) vents. it acts like all the vents are closed and it is either blowing to nowhere or the fan speed is very low...
even when i put it on full power...there is a slow trickle coming out...
cheers
Steve Toyota Corolla...Sad((((
Post #170764 Tue May 27 2008 2:06pm
Alicatt
Belgium 2008 Range Rover Sport TDV8 HSE Buckingham Blue
cheers
Steve
Had soething like that happen with an old 4x4 truck, the air duct had come off and was blowing behind the dash. Sons of dogs come hither and get flesh
Clan Cameron
Post #170766 Tue May 27 2008 2:24pm
Yeah, or the duct is blocked with something? I'm sure it's a bit more complex on the RRS, but I had an airvent block on an old car and when taken to pieces was full of leaves... Rolling Eyes
Post #170770 Tue May 27 2008 3:24pm
dont know how the think they recalibrated the AC fans - what exactly did they do? me thinks thats just a bit of lip service - I'd imagine they just rebooted the software - or did they actually measure the fan speed using a strobosope Laughing
Restricted airflow can be down to many things - faulty blower motors / faulty blower fan resistor / restricted inlet vent when in circ mode / software fault (the easiest to diagnose). LR have a defined specification for airflow from the vents which the dealer should check for you - if they cant, then let me know and I will confirm the airflow specs for all vents for you and if you can get hold of an anemometer you can do a rought check yourself (and then show them)
If you need anymore info then let me know
Post #170776 Tue May 27 2008 3:46pm
NickM
def close the rear vents - that helps with front flow...
Post #170794 Tue May 27 2008 6:28pm
tastech
Yeah thanks they were closed...
its like the system has decided that the air it is blowing is not the right temp so it decides to hold back blowing any air instead of the wrong temp...i set it 20 -22 c
Thanks ALL for your comments... Toyota Corolla...Sad((((
Post #170826 Wed May 28 2008 1:37am
tastech - when you choose the fan speed yourself, it will ignore the temperature selection - this is for auto mode only - you should be able to override the fan speed
Post #170843 Wed May 28 2008 10:06am
