| RRSPORT.CO.UK | ||
|  | Home > Technical > air con fan speed |
| tastech Member Since: 20 Nov 2007 Location: sydney, australia Posts: 94      |
 Hi has anyone experienced this?
|  Tue May 27 2008 12:13pm |
| Very Annoyed Site Moderator Member Since: 23 Aug 2005 Location: bat-wielding monkey-spanking tough-love zero-tolerance Euro-sceptic moderator - So just watch it! Posts: 19459    | Check you havn't got the system in auto mode (When the 2 lights are on on the dial.) 2005 Zambezi TDV6 - Gone but not forgotten
|  Tue May 27 2008 12:38pm |
| Jonny Fresh Member Since: 04 Feb 2008 Location: Manchester Posts: 3586    | A/C.....what's that?
|  Tue May 27 2008 12:39pm |
 HI VA Yeah full manual both lights off...i have selected about the 12 or 1 oclock position and middle (face level) vents. it acts like all the vents are closed and it is either blowing to nowhere or the fan speed is very low... even when i put it on full power...there is a slow trickle coming out... cheers Steve Toyota Corolla...  (((( formerly: RRS TdV6 Rimini Red, Alapaca, Sat Nav, Prem Ice, Hybrid TV, Cooler, FPS, Tow pack, roof mounted lighthouse | ||
|  Tue May 27 2008 1:06pm |
| Alicatt Member Since: 11 Jun 2007 Location: Eating in Eksel or Ice cold in Alex Posts: 1435      |
 Had soething like that happen with an old 4x4 truck, the air duct had come off and was blowing behind the dash. Sons of dogs come hither and get flesh Clan Cameron | ||
|  Tue May 27 2008 1:24pm |
| shmoogle Member Since: 07 Sep 2005 Location: ... and for every sprinkle I find, I shall kill you! Posts: 24350    | Yeah, or the duct is blocked with something? I'm sure it's a bit more complex on the RRS, but I had an airvent block on an old car and when taken to pieces was full of leaves...   | ||
|  Tue May 27 2008 2:24pm |
| Kaine Member Since: 26 May 2006 Location: Hills of Shropshire Posts: 8902    | dont know how the think they recalibrated the AC fans - what exactly did they do?  me thinks thats just a bit of lip service - I'd imagine they just rebooted the software - or did they actually measure the fan speed using a strobosope    | ||
|  Tue May 27 2008 2:46pm |
| NickM Member Since: 14 Feb 2008 Location: London Posts: 2995    | def close the rear vents - that helps with front flow... | ||
|  Tue May 27 2008 5:28pm |
 Yeah thanks they were closed... its like the system has decided that the air it is blowing is not the right temp so it decides to hold back blowing any air instead of the wrong temp...i set it 20 -22 c Thanks ALL for your comments... Toyota Corolla...  (((( formerly: RRS TdV6 Rimini Red, Alapaca, Sat Nav, Prem Ice, Hybrid TV, Cooler, FPS, Tow pack, roof mounted lighthouse | ||
|  Wed May 28 2008 12:37am |
| Kaine Member Since: 26 May 2006 Location: Hills of Shropshire Posts: 8902    | tastech - when you choose the fan speed yourself, it will ignore the temperature selection - this is for auto mode only - you should be able to override the fan speed | ||
|  Wed May 28 2008 9:06am |
| Posting Rules
