![]() | Home > General > SOAKING FLOOR |
umbertob Member Since: 23 Sep 2005 Location: Pasadena, CA Posts: 944 ![]() ![]() ![]() |
Let us know how it ends... I should mention that the above TSB is issued by LR North America, and the TSB # for other countires may not necessarily be the same, although most of the times it is. Check www.landrovertechinfo.com to verify if you want to mention a specific bulletin. You don't need a subscription to see bulletin titles, only to download the actual bulletin. |
Brian Mason Member Since: 31 Aug 2006 Location: Lurking with intent!!! Posts: 5326 ![]() ![]() ![]() |
Wouldn't let me in Umbertob, requires username and password.., or am I being blonde??? ![]() ![]() |
Martin Site Administrator & Owner Member Since: 26 May 2005 Location: Hook Norton Posts: 3662 ![]() ![]() |
You need to register, but you don't need to pay |
To my rescue again Martin, thanks! ![]() |
The ROW bulletin that matches the one from LRNA is titled: Range Rover Sport - Water Ingress via A-Pillar Exterior Trim or A-Pillar Trim Adrift - TSB # LS501-006. Sounds so much more interesting and important than our Yanks' version: A-pillar water leak... |
SALMON FISHER Member Since: 13 Jan 2007 Location: ,GLASGOW Posts: 115 ![]() ![]() ![]() |
HI GUYS
Kaine Member Since: 27 May 2006 Location: Hills of Shropshire Posts: 8902 ![]() ![]() |
could be right if the evap drain tubes haven't been fitted properly - if so, then they may need to take the dash out to get them refitted properly - hence the three days
TB Member Since: 19 Feb 2006 Location: Depends who wants to know . . . Posts: 5927 ![]() ![]() ![]() |
Isn't that one of your bits Kaine? |
yep - the drain tube was developed by TRW for DENSO/LR, however from memory the design was outside DENSO specs due to the packaging constraints made by LR ![]() also from memory I think the drain tube had to be fitted on the line by LR as the intention was to supply as a single part and not part of the AC assembly - but this may have changed since I was involved ![]() |
but this was over 3 years ago and my memory isn't the best |
That was a good guess on my part then. |
HI GUYS
So, was I right then with water ingress through door panel seal? Glad it's all fixed mate! |
fingers crossed |
