![]() | Home > Maintenance & Modifications > Slight Knocking Noise/Sensation felt through Steering Wheel |
| MDP Member Since: 15 Jun 2005 Location: Back in an AUDI Posts: 8598
HHHmmmm .... I have also noticed on my supercharged a slight knock at low speeds/turning... just able to feel something through your fingertips now and again - through the steering wheel/column ? Not sure if this is normal or not - but I have never had any car do this before. So ...... you've guessed, another call to dealer me thinks |
Me too! But I've had the steering column replaced following my smash. Happened before happens now! 2009 Alaska TDV8 - Gone and much missed.
WINNER - 2009 �Idler Of The Year� Award Runner Up - 2009 �Just Doing What It�s Designed To Do� Award DO NOT CLICK HERE! |
| Geordiehillbilly Member Since: 22 Aug 2005 Location: Newcastle Posts: 32
I got my steering rack replaced and it got rid of problem. Dealer done it under warranty too. Dealer reckoned it was to do with the 20" wheels I have??? |
My car is booked in this week for a list of things
" WITH MORE EXTRAS THAN A HOLLYWOOD EPIC " |
| RRUK Member Since: 10 Jun 2005 Location: Leicestershire Posts: 2589
Keep us posted on that one Martin, I too have felt this knocking feeling, feels like it's inside the column, like the shaft is banging inside it's housings somewhere (That's how I would describe it anyway)
The Park brake recall is one of the things it is in for.
| simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657
Upgrade time...
Damped steering rack or not - it still isn't perfect & LR are aware of these issues with the rack and I understand are investigating the problem.
| Persuader Member Since: 21 Oct 2005 Location: Wakefield Posts: 88
Finally got round to nipping into dealer yesterday re the knocking sensation/feeling coming through steering wheel. Mechanic came out with me and drove it and said it definitely isn't right. They have booked it in for next friday to sort it. They could have booked it in sooner but they say they want to order in all of the replacement bits for everything that could be causing the problem in order for them to definitely be able to fix it next friday - quite impressed with that.
Took it it in this morning. They are fitting a new steering column to see if that fixes it. Will let you know.................. 2013 New Range Rover Sport HSE SDV6
| Biggles Member Since: 26 May 2005 Location: Preston, Posts: 916
My sport has had a slight nock lately and I had set myself on letting it develop, but on my way into work this morning the nock got me so mad that I drove the car straight into our work shop and told the fitter not to stop pulling the car apart until he found the source of the noise.
| scorpio_ Member Since: 04 Nov 2005 Location: Birmingham, UK Posts: 5 |
I have had this same knock on my Discovery 3 and it is in the dealers at the end of the month for "a modified steerring colum mount" it has taken this long as the part required is not available till then. |
Had the ball joint replaced this morning and all seems well the irritating noise has gone and not surprisingly the steering feels a little more responsive and true. |
Well apparently the steering column is in 3 pieces. They had pre-ordered in the upper bit but upon investigation it is the middle bit that is faulty. The dealer told me that technical department are aware of this problem as it is becoming common but the spare parts are only just being made available to the dealers so we now have the car back awaiting a call from dealer when he gets part in. 2013 New Range Rover Sport HSE SDV6
