Home > Off Topic > reducing my energy consumption
Page 1 of 3 123>
Thought some may be interested in this
Over the weekend I went through the process of evaluating the energy consumption in my home - and I am SHOCKED!!!
Current estimated yearly Energy Consumpion is approx - 28700kWh Shocked Shocked - at first its seems wrong, however I've checked it and its pretty accurate.
Have spent today reviewing what I am going to change - both physical electrical equipment and also how we use the energy, I've given myself a target of 11940kWh
If like me you fancy some motivation to help reduce your energy consumption, then I recommend taking the time to see where you currently waste it - its quite scary and enlightening at the same time.
Post #75112 Sun Jan 14 2007 10:56pm
tf9
Russia 2006 Range Rover Sport Supercharged Java Black
Your watching too many greenpeace ads Laughing
Then you must know that the biggest evil you do to the nature is driving your 4x4 monster-truck (RRS) around the area Laughing 2014 Mercedes-Benz S500
2014 Range Rover Autobiography, Causeway Gray, Ivory/Ebony
2013 BMW 530d
2008 Range Rover Supercharged Vogue S\E, Java Black, Ebony. SOLD
2006 Range Rover Sport Supercharged, Java Black, Ebony. Arden body-kit. SOLD
2005 Range Rover Vogue 4.4 Buckingam blue, Ivory. - SOLD.
Post #75117 Sun Jan 14 2007 11:03pm
but my RRS does better mpg than the BM before - so that was an improvement for me Wink
Post #75119 Sun Jan 14 2007 11:06pm
homeins
2005 Range Rover Sport Supercharged Java Black
Energy Tips
try cavity wall insulation I did and my energy watse whent right down and you can get a grant i found that Home insulation Services were very good it only cost 249 the rest was paid for by Scottsh Power every one can get it just click www.homeinsulationservices.co.uk thank me when its saveing you all money on your energy bills
Post #75121 Sun Jan 14 2007 11:08pm
tf9
hmmm....
homeins...
homeinsulation...
homeinsulationservices.co.uk...
must be a coincidence Wink 2014 Mercedes-Benz S500
2013 BMW 530d
Post #75123 Sun Jan 14 2007 11:11pm
cheers homeins,
The house has Kingspan Thermawall throughout already - to be honest, the main problem is the electrical equipment in the house which is causing the biggest prob
Post #75124 Sun Jan 14 2007 11:12pm
homeins
Not bad
Well always pass on a good tip
Post #75125 Sun Jan 14 2007 11:12pm
TB
United Kingdom 2006 Range Rover Sport TDV6 SE Arctic Frost
My thoughts exactly. Good spot tf9. Thumbs Up Arctic Frost TDV6 SE. Aspen Leather, Cherry Wood, Privacy Glass, PTI, Tow Pack, Mudflaps, Tasmods, a new Fuelflap, a RRSport.co.uk umbrella in the boot & a RRSport.co.uk sticker on the rear glass.
__________________
Some people accuse me of thinking the world revolves around me, but I'm not stupid . . . I know it revolves around the sun. Which shines out of my @rse!!!
Post #75126 Sun Jan 14 2007 11:14pm
Tim in Scotland
Kaine, I've had an energy audit done by a friend in March 2006. My house is a 2 bed bunglaow built in 1985, it is "all electric". Some of the points that he raised for me were:
Turn off the tellies, dvd players, hifis and videoplayers and all the computers every night - leaving them on standby means they are fully powered up and ready to go. I was doing this anyway as I don't have a telly so don't have the hassle of resetting the clock on it or the other gear!
Turn down your water heater to 40C-45C
I was looking to change my electric company to a greener supplier (I'm with Scottish Hydro who don't actually use much hydro power these days!) but when I added up how much electricty I use over a year (my TOTAL bill last year was £263!) I found that it wasn't worthwhile changing - everybody else was going to cost me more! Remember I'm only here for 6months a year, but I do heat the house when I'm away in the winter.
I you have an upright type deepfreeze consider changing it for a chest freezer - you don't loose all the coldness every time you open a chest freezer! Also if the freezer is only run partly filled rather than chockablock full fill the empty airspace with bags of polystyrene beads or screwed up newspapers so you don't have to cool that airspace as well, reducing the time the freezer motor runs.
Here is one that saves a heap of energy too - watch how much water you heat whenever you fill a kettle - only fill the kettle with as much water as you need to heat, don't rehat the same water 2-3 times over - If you are only making cuppas for two you will find the kettle boils more quickly too with less water to heat!
Have you checked that any outside lights are not staying on all day as well as all night - replace them with energy saver lamps too if you can, they use less energy and last a lot longer than incandescent lamps (I've just replaced the first ones in my house after 13 years of use!).
At the time the audit was done I was having new double glazing fitted so he couldn't get me on that, but he took one look in the loft and asked when i last replaced the loft insulation or added extra thickness........... although they did ask why i had duvets laid............... I've been recycling old ones as additional loft insulation and probably have the only 13.5 tog rated loft insulation in the country!!
Reduce the time you spend in the shower if it is an instant heat job, cut out one verse of the song you sing in there! You'll save energy and water! My shower is a gravity fed mixer tap drawing from the hot tank so I couldn't do much about that, other than reducing the song by one verse! Laughing 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #75137 Mon Jan 15 2007 12:04am
The doc
O M F G
GP is making us M A D Shocked
What have we started Laughing
Post #75205 Mon Jan 15 2007 10:38am
The doc wrote:
O M F G
to be hoenst the only reason I did this was because I saw our latest electricity bill this week - £438 for the quarter - I dont normally see the house bills, but that shocked me
Plasma is going next week - soon to be replaced with a 1080p LCD - not a big fan of LCD normally, but energy savings are HUGE!!!!
42" Pana Plasma - 295W
40" LCD (e.g. Sharp) - 20W
that one change will save me over £200/year Shocked Shocked
Post #75501 Mon Jan 15 2007 11:36pm
homeins
save even more
excellent - try insulating your loft 249 @ homeinsulationservices.co.uk
i have a wind turbine at the rear of our garden its fantastic and provides all mour elecy
Post #75503 Mon Jan 15 2007 11:39pm
Tim in Scotland
Kaine you need to share that with the GP guys...................... you've made a conscious decision to save the earth! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #75504 Mon Jan 15 2007 11:42pm
ENVOY
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Arctic Frost
£438 holly Censored Censored
Mines come in at £150 for the last quarter some of my Previous cars
P38 Range Rover Autobiography
RRS 2.7 HSE Silver
RRS TDV8 HSE silver
FFRR Vogue black
Disco3 HSE silver
RRS 2.7 HSE silver
RRS 3.0 HSE BALTI BLUE
current vehicles
RRS 3.0 L494 Autobiography
Audi R8 V10 Spyder
AC Cobra
Landrover Defender 90
Landrover Defender 110
Suzuki Jimney
Post #75505 Mon Jan 15 2007 11:43pm
Laughing Laughing - no way - not sure they'd like me very much
Post #75507 Mon Jan 15 2007 11:47pm
Page 1 of 3 123>
