Home > Technical > TMC - Storing Classic FM.....or not???
Does your RRS save the Classic FM channel correctly?
Yes
54%
 54%  [6]
No
45%
 45%  [5]
Total Votes: 11
simonsi
United Kingdom 2007 Range Rover Sport TDV6 HSE Arctic Frost
Having searched I find several cars not storing the Classic FM channel for TMC, my 2007 doesn't store it either but has anyone found a solution? Dealer wants it for a day, LR Cust Care say they've never heard of the problem (big surprise). The Satnav is clearly Alpine-sourced but the Alpine satnav in my D2 works just fine so I'm a bit puzzled..... Cheers
Simon
2007 2.7HSE 20" Wheels
2005 TDV6 D3 S Auto - Zambezi Silver - JE Tune - RRS 19" - Sidesteps - Roof Rails
Body Side Strips - Xenons - Bright Pack - Cold Pack - Premium Stereo
Alpine Roof - Towpack - Alpine Touchscreen Satnav - Veba Rear DVD changer
Alpine Roof Monitor - Webasto FBH Timer - Brembo Frt & S/C Rr Brakes
Post #68735 Fri Dec 01 2006 5:22pm
As far as I understand it, you don't need to "store" Classic FM to get TMC updates (I never stored in on mine and managed to still get TMC to work) but your car does need to be able to receive it. This is what seems to be the problem for a lot of people - patchy reception. If you listen to the station as you drive around, is it clear?
Post #68738 Fri Dec 01 2006 5:27pm
Landlord
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Alaska White
I pressed the seek command whilst in UK and it found the appropriate channel - from then on received TMC.
Now here in Holland have not touched it and still receives TMC info. Not sure how the thing works but it does - so no problem. MY10 TDV6 HSE, Alaska White, Ebony with Contrast, Park Heat, Paddle Shift, Privacy, Heated Steering Wheel, Extended & Premium Leather,
MY07 TDV6 HSE, Zermatt Silver, Gone
1964 Austin Healey 3000
2007 LR Defender
2011 VW Tiguan R Line
Post #68767 Fri Dec 01 2006 7:43pm
Singletrack
Belgium 2006 Range Rover Sport TDV6 HSE Java Black
Never set it here in Belgium either but it works...and much better than with the navigation system in our Volvo. The volvo requires that a destination be entered for the TMC to work while in the RRS it works in map mode. Very nice Very Happy 2006 Range Rover Sport TDV6 HSE, Java/Ebony/Cherry, Privacy, Sunroof, PTI, Premium Sound, SatNav, Cold Climate, Tow kit, CarStyle coded grill and vents, Tasmods, Stormers, JE Exhaust, Autobiography badge
Post #68770 Fri Dec 01 2006 8:06pm
simonsi
Reception of Classic FM is fine, my problem is that after turning the ignition off and back on it will retune to Heart FM and needs a scan to find Classic again......?? Cheers
Simon
Post #68822 Sat Dec 02 2006 10:33am
nickp
United Kingdom 2005 Range Rover Sport TDV6 HSE Zambezi Silver
Hi Simon
I have and have had since the car was new the same problem. Mine has been back at the dealers many times , but they have no solution. It seems strange but I live in the same area as you and always have the problem here . I went down to the South West in the summer for two weeks and had no problem at all . There must be a solution .
Regards
Nick.
Post #69590 Fri Dec 08 2006 12:10am
simonsi
Antennae??
Hi Nick, I'm pretty convinced its an antennae issue, given the base satnav is Alpine I'll bet it has a seperate antennae for the TMC tuner in the sat nav box. My D2 has Alpine satnav with TMC and seems much better even in the same location...I'll try and find out the antennae config as it >may< be possible to fit an Alpine antennae and improve things.... Cheers
Simon
Post #69769 Fri Dec 08 2006 5:22pm
philmw
United Kingdom 2012 Range Rover Sport Supercharged Sumatra Black
This is the problem with mine, and I think I posted this question before. If you start the system in an area where reception is bad the Sat Nav starts to retune and locs on to the nearest station. I park daily in an underground carpark. I wish there was a way to stop this automatic retune, as only Classsic FM broadcast TMC in the UK.
Post #69792 Fri Dec 08 2006 6:31pm
Slimer
Re: TMC - Storing Classic FM.....or not???
simonsi wrote:
The Satnav is clearly Alpine-sourced.....
Nope, it's from Denso & NavTeq
Post #69795 Fri Dec 08 2006 6:53pm
Tim in Scotland
Unless you have the 2007MY in which case it is an Alpine unit............... 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #69796 Fri Dec 08 2006 6:55pm
Slimer
Ah, well you learn something everyday, if it's the same data disc I'm partly right then Wink
Post #69797 Fri Dec 08 2006 6:57pm
Tim in Scotland
Slimer, the satnav display unit is Alpine and the satnav software is Navteq 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #69800 Fri Dec 08 2006 7:16pm
Slimer
Cheers Tim Very Happy
Post #69803 Fri Dec 08 2006 7:29pm
simonsi
Mine is 07MY...
Hmm - the unit looks vaguely Alpinish but without the smartish cover, the operating software is clearly Alpine derived (so similar I found out about a function on my Alpine satnav by reading the RRS manual), no idea whose mapping Alpine or LR use, the Alpine disc carries both the operating system for updating and the mapping data.
Still waiting for some time to trace the antennae connection to the box.... Cheers
Simon
Post #69911 Sat Dec 09 2006 9:05pm
