| RRSPORT.CO.UK | ||
|  | Home > Technical > TMC - Storing Classic FM.....or not??? |
| shmoogle Member Since: 07 Sep 2005 Location: ... and for every sprinkle I find, I shall kill you! Posts: 24350    | As far as I understand it, you don't need to "store" Classic FM to get TMC updates (I never stored in on mine and managed to still get TMC to work) but your car does need to be able to receive it. This is what seems to be the problem for a lot of people - patchy reception. If you listen to the station as you drive around, is it clear?  | ||
|  Fri Dec 01 2006 4:27pm |
| Landlord Member Since: 26 Sep 2006 Location: Hampshire Posts: 607      | I pressed the seek command whilst in UK and it found the appropriate channel - from then on received TMC.
|  Fri Dec 01 2006 6:43pm |
| Singletrack Member Since: 07 May 2006 Location: Belgium - Lasne Posts: 330      | Never set it here in Belgium either but it works...and much better than with the navigation system in our Volvo.  The volvo requires that a destination be entered for the TMC to work while in the RRS it works in map mode.  Very nice  | ||
|  Fri Dec 01 2006 7:06pm |
| simonsi Member Since: 01 Dec 2006 Location: Leicester Posts: 259      |
 Reception of Classic FM is fine, my problem is that after turning the ignition off and back on it will retune to Heart FM and needs a scan to find Classic again......?? Cheers Simon 2007 2.7HSE 20" Wheels 2005 TDV6 D3 S Auto - Zambezi Silver - JE Tune - RRS 19" - Sidesteps - Roof Rails Body Side Strips - Xenons - Bright Pack - Cold Pack - Premium Stereo Alpine Roof - Towpack - Alpine Touchscreen Satnav - Veba Rear DVD changer Alpine Roof Monitor - Webasto FBH Timer - Brembo Frt & S/C Rr Brakes | ||
|  Sat Dec 02 2006 9:33am |
| nickp Member Since: 27 May 2005 Location: Leicestershire Posts: 111      | Hi Simon
|  Thu Dec 07 2006 11:10pm |
 Hi Nick, I'm pretty convinced its an antennae issue, given the base satnav is Alpine I'll bet it has a seperate antennae for the TMC tuner in the sat nav box. My D2 has Alpine satnav with TMC and seems much better even in the same location...I'll try and find out the antennae config as it >may< be possible to fit an Alpine antennae and improve things.... Cheers
|  Fri Dec 08 2006 4:22pm |
| philmw Member Since: 18 Aug 2006 Location: Nottingham Posts: 1691      | This is the problem with mine, and I think I posted this question before. If you start the system in an area where reception is bad the Sat Nav starts to retune and locs on to the nearest station. I park daily in an underground carpark. I wish there was a way to stop this automatic retune, as only Classsic FM broadcast TMC in the UK. | ||
|  Fri Dec 08 2006 5:31pm |
| Slimer Member Since: 26 May 2005 Location: Nanny State Posts: 224    |
 Nope, it's from Denso & NavTeq | ||
|  Fri Dec 08 2006 5:53pm |
| Tim in Scotland Member Since: 30 May 2005 Location: Driving along in my automobile Posts: 17476    |
 Unless you have the 2007MY in which case it is an Alpine unit............... 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it 2018 Melting Silver Mini Countryman PHEV - soon to be replaced 2015MY Corris Grey SDv6 HSE Dynamic, the best car I have ever owned, totally reliable only a cou0le of rattles in 3 years, now no longer in my care Also in my garage is a 1996 TDi300 Defender 90 County HT made into a fake CSW | ||
|  Fri Dec 08 2006 5:55pm |
| Slimer Member Since: 26 May 2005 Location: Nanny State Posts: 224    | Ah, well you learn something everyday, if it's the same data disc I'm partly right then  | ||
|  Fri Dec 08 2006 5:57pm |
| Tim in Scotland Member Since: 30 May 2005 Location: Driving along in my automobile Posts: 17476    | Slimer, the satnav display unit is Alpine and the satnav software is Navteq 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
|  Fri Dec 08 2006 6:16pm |
| Slimer Member Since: 26 May 2005 Location: Nanny State Posts: 224    | Cheers Tim  | ||
|  Fri Dec 08 2006 6:29pm |
 Mine is 07MY... Hmm - the unit looks vaguely Alpinish but without the smartish cover, the operating software is clearly Alpine derived (so similar I found out about a function on my Alpine satnav by reading the RRS manual), no idea whose mapping Alpine or LR use, the Alpine disc carries both the operating system for updating and the mapping data. Still waiting for some time to trace the antennae connection to the box.... Cheers Simon 2007 2.7HSE 20" Wheels 2005 TDV6 D3 S Auto - Zambezi Silver - JE Tune - RRS 19" - Sidesteps - Roof Rails Body Side Strips - Xenons - Bright Pack - Cold Pack - Premium Stereo Alpine Roof - Towpack - Alpine Touchscreen Satnav - Veba Rear DVD changer Alpine Roof Monitor - Webasto FBH Timer - Brembo Frt & S/C Rr Brakes | ||
|  Sat Dec 09 2006 8:05pm |
| Posting Rules
