| RRSPORT.CO.UK | ||
|  | Home > My Range Rover Sport > Cold air blowing in car when dial is on hot |
| mikeyranson Member Since: 31 Oct 2013 Location: london Posts: 20      |
 2010 RRS 3.0l
|  Tue Jan 28 2025 11:01pm |
| mikeyranson Member Since: 31 Oct 2013 Location: london Posts: 20      | I have that as a possible next stage. The dashboard has to come out to change the acuator. i believe mine is working correctly. The control valve is a common problem and as mine is 2010, i am going fr the easiest fix and hopefully that is the problem. If i have to look at the acuators then i just as well change the matrix whilst there.
|  Fri Oct 24 2025 8:19pm |
| Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 359      | I made a kit up to blast out the heater matrix on the sports and d3 cars, they use exactly the same heater matrix. As you have heat 1 side and not the other give it a good blast with air and water mix I bought a gun off the bay that connects to my garage air tank and water hose a quick blast and it solved the issue.
|  Sat Oct 25 2025 5:53pm |
| mikeyranson Member Since: 31 Oct 2013 Location: london Posts: 20      | i will try the reverse flush.  good idea. I am tempted to buy a garden pond pump to try it as well.
|  Sun Oct 26 2025 8:19am |
| MrClarkyy Member Since: 30 Oct 2025 Location: West Yorkshire Posts: 4      | Hi,
|  Thu Oct 30 2025 6:26am |
| mikeyranson Member Since: 31 Oct 2013 Location: london Posts: 20      | you have the same what i have. there are four possibles i have found, matrix, actuator and heater control valve. I'm going for the heater control valve first if i can find out where it is fitted exactly. The actuator and matrix is dashboard out for both, hence why i am trying the easier method first. | ||
|  Thu Oct 30 2025 8:07pm |
| MrClarkyy Member Since: 30 Oct 2025 Location: West Yorkshire Posts: 4      | Cheers for the reply.
|  Thu Oct 30 2025 9:53pm |
| MrClarkyy Member Since: 30 Oct 2025 Location: West Yorkshire Posts: 4      | Would heater controller valve show a fault when scanning?? | ||
|  Thu Oct 30 2025 9:54pm |
| Posting Rules
