![]() | Home > My Range Rover Sport > Cold air blowing in car when dial is on hot |
| mikeyranson Member Since: 31 Oct 2013 Location: london Posts: 18
2010 RRS 3.0l
I have that as a possible next stage. The dashboard has to come out to change the acuator. i believe mine is working correctly. The control valve is a common problem and as mine is 2010, i am going fr the easiest fix and hopefully that is the problem. If i have to look at the acuators then i just as well change the matrix whilst there.
| Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 358
I made a kit up to blast out the heater matrix on the sports and d3 cars, they use exactly the same heater matrix. As you have heat 1 side and not the other give it a good blast with air and water mix I bought a gun off the bay that connects to my garage air tank and water hose a quick blast and it solved the issue.
