| RRSPORT.CO.UK | ||
|  | Home > Maintenance & Modifications > Electric handbrake recoding ?? |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145      | I wouldn't waste time swapping boards, unless you are doing the whole job yourself.
|  Mon Oct 27 2025 3:54pm |
| Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 477      | So you have not done the job and dont know the answer.................................WOT
|  Tue Oct 28 2025 7:15am |
| NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 522      | I’ve done a few, always had to go into JLR-SDD and tell it there was a new EPBM.
|  Tue Oct 28 2025 11:22am |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159      | It needs to be calibrated which is presumably what the garage means by "coding".
|  Tue Oct 28 2025 1:15pm |
| Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 477      | Supplier of EPB  says no coding required  . Hence the idea to re build the original  coded parts into a replacement..just change the motor or board Always listen to old people or when they die you will live on in ignorance.
|  Tue Oct 28 2025 1:24pm |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159      | Workshop manual says requires calibrating using the JLR SDD.
|  Wed Oct 29 2025 3:45am |
| Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 477      | Thanks for that V8   so its swop the new motor into the old unit or swop the circuit board  ..will let you know how it went    !) days .. Always listen to old people or when they die you will live on in ignorance.
|  Wed Oct 29 2025 8:08am |
| Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 477      | UPDATE
|  Wed Oct 29 2025 12:16pm |
| Posting Rules
