Home > Maintenance & Modifications > Electric handbrake recoding ??
Pistnbroke
Have conflicting information . Seller of new unit says it does not kneed coding by a dealer but a garage has told me they have to take it to a dealer for coding which puts up the cost .
I was considering buying a new unit and either swopping the circuit board from the old unit into it or fitting the motor/gearbox from the new unit into the old to maintain the coding in the unit .
Any thoughts currently the brakes are seized ON Always listen to old people or when they die you will live on in ignorance.
Post #650342 Mon Oct 27 2025 3:12pm
I wouldn't waste time swapping boards, unless you are doing the whole job yourself.
Ask the garage if the price will be less if it doesn't need coding.
I think you need to tell it the car is an auto or manual (disco)
Post #650343 Mon Oct 27 2025 3:54pm
Pistnbroke
So you have not done the job and dont know the answer.................................WOT
If anyone has done this job and can give real life information please respond. Always listen to old people or when they die you will live on in ignorance.
Post #650354 Tue Oct 28 2025 7:15am
NoExpert
I’ve done a few, always had to go into JLR-SDD and tell it there was a new EPBM.
Did the EPBM jam up? There’s an unjamming procedure in diagnostics and it’s also possible to take them apart and unjam them. Then you need to adjust the parking brake shoes by the book to prevent it happening again, for a little while at least.
You can pull the emergency release cable under the cup holders, should get you moving at least. If not you have jammed park brake shoes or cables. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #650363 Tue Oct 28 2025 11:22am
It needs to be calibrated which is presumably what the garage means by "coding".
As NoExpert says, that requires the SDD. Doesn't need to be a dealer, a suitably JLR independent can do it as they will have the necessary kit too. I'd be surprised if a main dealer would calibrate it unless they'd supplied and fitted it (at great expense, no doubt). 2012 SDV6 - it's missing a couple of cylinders
Post #650366 Tue Oct 28 2025 1:15pm
Pistnbroke
Supplier of EPB says no coding required . Hence the idea to re build the original coded parts into a replacement..just change the motor or board Always listen to old people or when they die you will live on in ignorance.
Post #650367 Tue Oct 28 2025 1:24pm
Workshop manual says requires calibrating using the JLR SDD.
Your choice, as always. 2012 SDV6 - it's missing a couple of cylinders
Post #650372 Wed Oct 29 2025 3:45am
Pistnbroke
Thanks for that V8 so its swop the new motor into the old unit or swop the circuit board ..will let you know how it went !) days .. Always listen to old people or when they die you will live on in ignorance.
Post #650374 Wed Oct 29 2025 8:08am
Pistnbroke
UPDATE
At dealership brakes locked up and would not respond to emergency release.
Cut braked cables and able to drive vehicle with warning lights.
Plan to replace motor/gearbox and cables from £120 e bay unit .
Will keep you informed Always listen to old people or when they die you will live on in ignorance.
Post #650393 Wed Oct 29 2025 12:16pm
