![]() | Home > General > Steering wheel play and failed MOT |
| Frax Member Since: 07 May 2015 Location: Aberdeenshire Posts: 254
Hi I have a L320 2011 Range Rover Sport HSE, it went for its MOT today and failed on steering wheel play, I had never noticed it but there was about 10mm of play in the steering wheel, he told me that the play was in the slide and not the joint, Can these be tightened up - he did say it looked almost new and said it was probably a cheap part, not fitted by me,
| Chris123 Member Since: 14 Jul 2025 Location: Halifax Posts: 8
following, as my 2010 model currently has the same issue, (not MOT failure yet) |
New column. Only fit genuine. Not cheap, but the aftermarket parts are horrendous quality |
Thanks Mikey thought as much, where would I find the correct part number, I will look if you just point me in the right direction, think I have found it LR071146
LR071146 |
New steering shaft fitted, and I could tell the difference, did buy the Land Rover part, the job it's self was not as bad as I thought it would be bottom bolt was a bit of a fiddle but removed that and pushed the shaft up and was able to remove it from the shaft on the box, next was the top which I got from the engine bay, you need a few extensions and a 10mm socket, be sure to make sure the socket is on properly or it will slip, to find the nut you need to look down the edge of the left plastic box if you face the engine.
| RallyeSport Member Since: 20 Jun 2024 Location: Gloucester Posts: 111
Flax,
Hi Dean I bought the shaft from John Craddock, it cost me £283.21 + £10 for next day delivery and it was a genuine Land Rover shaft, quite a bit of money for what it is but hope it will never need done again. Lot of Landcruisers now sold
