![]() | Home > General > Steering wheel play and failed MOT |
Frax Member Since: 07 May 2015 Location: Aberdeenshire Posts: 252 ![]() ![]() ![]() |
Hi I have a L320 2011 Range Rover Sport HSE, it went for its MOT today and failed on steering wheel play, I had never noticed it but there was about 10mm of play in the steering wheel, he told me that the play was in the slide and not the joint, Can these be tightened up - he did say it looked almost new and said it was probably a cheap part, not fitted by me,
Chris123 Member Since: 14 Jul 2025 Location: Halifax Posts: 6 ![]() ![]() |
following, as my 2010 model currently has the same issue, (not MOT failure yet) |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4531 ![]() ![]() ![]() |
New column. Only fit genuine. Not cheap, but the aftermarket parts are horrendous quality |
Thanks Mikey thought as much, where would I find the correct part number, I will look if you just point me in the right direction, think I have found it LR071146
LR071146 |
