![]() | Home > General (L494) > Buying Advice |
41jules1967 Member Since: 01 Jun 2025 Location: Leeds Posts: 149 ![]() ![]() |
I wrestled with this one.
Kitchenfitter Member Since: 20 Feb 2021 Location: CV61AH Posts: 354 ![]() ![]() |
Thank you
scrumps Member Since: 01 Aug 2011 Location: Somerset Posts: 586 ![]() ![]() |
Nice to hear the D300 will crack 40mpg - not achieved that yet. If it can do that on a run, that'd be great, though to be fair, with my right foot, it's probably unlikely - but that's my fault.
Almost - my '21 494 D300 is the 48V MHEV with the belt driven starter/generator setup - so as far as I know, the exact same engine setup as in the L461. Slightly earlier ones than mine had the V6 Diesel so I assume mine was one of the first with this setup which then rolled into the L461. I guess it gave them chance to test it out on the public before the new model was released.
timhum Member Since: 06 Mar 2017 Location: Suffolk Posts: 391 ![]() ![]() |
I knew there had to be a mpg reading that was accurate somewhere. In my experience of 14 Jaguar and LR vehicles all were about 10% optimistic. Tim RRS sold and replaced with a Skoda Kodiaq after appalling RR Dealer experience and LR inability to supply new cars in any sort of reasonable time frame.. |
ShouldHaveStuckWithAudi Member Since: 20 Nov 2023 Location: Godstone Posts: 36 ![]() ![]() ![]() |
Hi all, was hoping to jump in on this one with a slightly different steer. I'm looking to get rid of the MY13 RRS 3.0SDV6 and upgrade to a MY17 RRS, also the 3.0SDV6.
Yes, all the TDV6's, whether the 2.7 or the last 300bhp one are basically the same engine, just with a few tweaks, mostly in software. Not sure if the 300hp has larger injectors but the basics are still the same.
2 RRS Member Since: 04 Sep 2016 Location: Shropshire Posts: 242 ![]() ![]() ![]() |
The 2013 SDV6 would be a Gen 1 unit, whereas the 2017 would be Gen 2, the block is slightly different to accomodate an electrically switchable oil pump and water pump (the blocks are not interchangeable). Not sure electronically reducing oil pressure in the name of economy is a good thing in my mind! |
Hi again, didn't end up getting that MY17 RRS as the chap couldn't find any proof of ownership nor a single service in 95K miles....I was too scared to even test drive it.
jimbg Member Since: 29 Jan 2013 Location: No longer by the River Dart.... Posts: 1922 ![]() ![]() |
I do not think many of those were sold as far as I remember it was a tiny battery that just added complication rather than range.
hmm - the 3.0h SDV6 is a very rare beast. So much so, I'd never heard of it and assumed you'd got it confused - but no, it does exist. A quick trawl of autotrader, with hundreds of RRSs brings back only 4 so they couldn't have sold many. Apparently it was priced to match the SV which may go some way to explaining that.
I know someone who had the same powertrain in the L405, HV battery failed and as it charges the 12v battery within a few miles its a total shutdown. New batteries no longer available, tried to get the HV battery repaired and was unsuccessful, the car has been off the road ever since.... |
