Home > General > Criticaly low oil level
Matt123l
Hi, i had a warning on the dash for criticaly low oil level, stopped the car and checked and it disapeared and the oil level said it was full so continued to drive, checked again and it said i need to add a litre , then checked again after some more driving and it said it was full, has anyone ever had this? Its on a 2018 sdv6
Post #650168 Sat Oct 11 2025 10:09pm
I think your options are a bit limited as It is not possible to manually check the level, it is not unknown for the sensor's to go faulty which is I believe a major job to replace on the diesel version, personally I would drain and check the quantity of oil in the engine to see how it compares to what is the correct amount for that engine and go from there.
Post #650169 Sat Oct 11 2025 10:45pm
Matt123l
It was serviced 4k miles ago and i reguarly check oil level and has always been at the full level,so i assume the oil level is fine but i dont know what else it would be other than the sensor
Post #650170 Sat Oct 11 2025 11:00pm
Notyalc
I have read where people use some net curtain wire to poke down the fill/drain tube on the SDV6 engine. Maybe on the D4 forum for lengths etc. this can give you an indication of how much oil you have. Does not fix the sensor issue obviously if that is your problem.
Post #650175 Sun Oct 12 2025 5:30pm
Matt123l
I took off the undertray today and noticed there is some oil on the bottom of the engine, i think it may be coming from the oil cooler, so im hoping this oil leaking has just ran down the loom and into the plug for the level sensor as there is a slight pit of oil in it when i unplug it, if this leak dosent fix it then its obviousy a faulty sensor, i have taken a few measurments today and it says oil level is fine
Post #650176 Sun Oct 12 2025 5:33pm
Matt123l
Post #650177 Sun Oct 12 2025 5:33pm
