![]() | Home > General > Squelching Noise |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5147
carpets wet ? |
| Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 428
The suspension works fine - the vehicle is level and rises/lowers quickly.
| Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 479
Could the sound be like training shoes on a squash or tennis court, squeaks every time you go over a bump or pothole,, If it is its the shock absorber, just done mine.. =========================================== 2012 Range Rover Sport Autobiography 3.0 SDV6 8 speed Automatic Indus Silver with Hockenheim premium two-tone leather Ebony/Lunar, |
I drove the car yesterday with the driver's window open and the noise tuned out to be a very loud "Seagull squarking noise" outside of the vehicle (best I can describe it) when going over certain bumps. It doesn't happen over every bump and the vehicle handling as far as I can ascertain, has not gotten any worse from when there was no noise at all - it certainly handles fine, very well damped and no controlability problems. I am going to change the suspension struts on all four corners and fit some Bilstein high-pressure gas shock absorbers. I don't see much point in just changing the shock absorbers alone, given the vehicle's age. |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159
If you rock the car whilst it's parked, do you get the noise? Around the rear wheels? If so, sounds like a knuckle bush (the bushes that connect the upright to the suspension arms). Had this on mine a few years ago. The rubber was split and wear had inevitably occurred. New bushes silenced the noise.
RRSTV8
| All times are GMT |
