![]() | Home > General (L494) > Service level indicators |
| scrumps Member Since: 01 Aug 2011 Location: Somerset Posts: 586
| Ade RRS Member Since: 19 Jun 2025 Location: Midlands Posts: 13
Thanks Scrumps
I'm pretty sure it's adaptive. If you do some town driving, it drops quickly, then increases after a longer motorway journey |
| RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9155
That would be an algorithm-based system at work then. Much like social media, it assumes that if you're doing X now then that's what you'll keep doing and make recommendations accordingly. Change your behaviour and see a different suggestion. 2012 SDV6 - it's missing a couple of cylinders
Hi, I’m sure there’s a brain in the car somewhere that looks at how much extra fuel is put into the system to improve DPF re-generation. It probably works out how many extra doses its has done and calculates at what point it will be excessive and estimates time or mileage. As it’s a forward projection, it can go up or down! I used to do 100 ml commute , sometimes 200 mls to another site so mine didn’t need to re-gen too often, If I was running round locally then it varied! Scrumps Somerset - Where the apples do grow and the cider do flow! 2021 Defender 90 D250 HSE in Tasman with white roof. 24MY D300 AB - Verasine Blue - 😀 19MY SDV6 AB - Byron Blue - Gone 17MY D5 SDV6 HSE - Firenze Red - Gone 16MY SDV6 AB -Aruba Silver - Gone 13.5MY SDV6 "HSE Black" - Baltic Blue - Gone 10MY TDV8 HSE Galway Green - Gone 14MY D4 HSE in Scotia Grey - Gone 05 TD5 D90 CSW in Cairns Blue |
