Home > General (L494) > P400e Air suspension Compressor location.....?????
2 RRS
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Bourneville
Do you also have a HV heater failure (vehicle fails to drive from start in Ev mode if aircon / heating is on), that's a pretty common fault as well I believe!
Post #650022 Wed Oct 01 2025 10:17am
Clarkie2488
Ill add that to the list for the boys to fix, hope I don't have a Friday 5 O'clock car Laughing Laughing
Stewart
Post #650024 Wed Oct 01 2025 10:47am
Clarkie2488
UpDate, The Sport is to back to 100%,,, EV Heater fixed (Under warranty) and air suspension fixed too.
So the Air Expansion chamber had failed # LR140035, Funny thing they had a few of them in stock, so must be a weak point. (Warranty too) as I thought they needed to remove the EV battery to access the compressor, however talking to the Tech, he said that if the EV heater was not getting changed and coolant dropped, he would have unbolted the EV Battery and propped up the battery enough to access the one bolt to remove the 12v battery tray, so good to know if I need to go in there again.
HV Heater was a swap out and again they had that in stock and admitted they pop quite a lot too.
Thank you again to all that helped out and 2RRS for spotting the HV heater fault.
Take Care . Stewart
Post #650235 Fri Oct 17 2025 1:13pm
