Home > General (L494) > P400e Air suspension Compressor location.....?????
Clarkie2488
Good evening, new to site, just a question and after hours and hours of searching I have decided to reach out for Help and advice,,, SO air suspension compressor has pooped it self humming but not running, seen all the info of how to fix, replace and calibration.... but my question is, this is a P400e and where the Compressor would be in the spare wheel well, I have a BIG HV Battery and no compressor, does anyone have access to P400e drawings or Maintenance manuals for the p400e air suspension system.. Thank you..
P.S this photo a screened shot from a few lads on YouTube taking the EV battery out... Bow down
Post #649984 Mon Sep 29 2025 8:38pm
Clarkie2488
Post #649987 Tue Sep 30 2025 4:04am
jimbg
 2026 P460e Autobiography on order
2022 HSE Dynamic P400e
2006 HSE
Post #649989 Tue Sep 30 2025 7:59am
2 RRS
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Bourneville
Not sure this is much help, but the parts diagram still shows it in the boot area in a different casing to the normal unit.
https://parts.jaguarlandroverclassic.com/p...and-rover/
Post #649991 Tue Sep 30 2025 11:25am
Clarkie2488
That's fantastic, Thank you so much, as you said it still shows inside the boot, just trying to figure out if under the battery tray is the compressor as seen in the photo. but its a start and ill see if I can rummage around and get back to you all.. Thanks again.....
Post #649995 Tue Sep 30 2025 3:14pm
Clarkie2488
So after getting help pointing me in the right direction by 2RRS, I found the compressor under the 12v main Battery, however, the battery tray is bolted down on top of the compressor tray, and unfortunately I cannot remove one bolt as it is right under the EV battery and I would have to remove it to gain access, I have taken a few photos and hope fully they will load up this time (Thank you Jimbg) still trying to figure out this site. Thanks for all the help, Off to the stealers I go ..............
Post #649999 Tue Sep 30 2025 5:55pm
2 RRS
Nice bit of engineering! Can you not loosen the 48v battery enough to raise it to access the battery tray / compressor housing?
Post #650000 Tue Sep 30 2025 6:02pm
Clarkie2488
I have circled where you can see into the compressor box
Post #650001 Tue Sep 30 2025 6:03pm
Clarkie2488
The car is under a Autocrat warranty, and as it was a two week wait until they get it in, I wanted to see if I could check all the usuals, Connections, exhaust and intake just incase it was a simple fix, I would be worried about the battery coolant system getting messed up, so I'll just wait out and let the techie shock him self,,
Post #650002 Tue Sep 30 2025 6:08pm
2 RRS
I don't think he'll be worried about 48v, but if you've got a warranty I guess it's best to go through the motions of claiming on the warranty rather than messing something up.
Never read of a compressor failing on a P400e, thought they were too new for this, then again it's a LR!!
Post #650003 Tue Sep 30 2025 6:13pm
Clarkie2488
Yes its a strange one to go so soon, you can hear the compressor running, then ping of doom, "air suspension fault and forward alert not available after 50Mph" it does not have the Veh Orange light as with my D3, it has Information big I, the system holds pressure, Gap tool has 3 faults . Cambus, Suspension and Forward alert , clear all them and the compressor will kick in and we go back round in a loop again ???
Post #650005 Tue Sep 30 2025 7:14pm
2 RRS
I'd say you've diagnosed that correctly, what's the suspension dtc that the IID is giving, will that give you any guidance.
Post #650006 Tue Sep 30 2025 9:00pm
Clarkie2488
Morning, Just did a check of the dtc's, and as you can see the good old C1A20-64 (2F) slow filling code,
I did a wee bit of research on NEW issues with the compressors and found one relating to a new Defender and the Expansion chamber failing (Please see Link below) and the fix, I also found a Technical bulletin in the US with Ref to the same part ( See below ), However its just a bit of a pain having the EV battery covering a Bolt, but I'm sure there will be a better fix in the future.
Thanks again fore all your help
Stewart
https://static.nhtsa.gov/odi/tsbs/2018/MC-10149096-9999.pdf
https://landroverforums.com/forum/new-disc...or-123493/
Post #650019 Wed Oct 01 2025 9:58am
2 RRS
Seems that the expansion chamber part no. has superceded a few times, so that's always a pointer to a problem being re-engineered by JLR. Ultimatley, you still need to get to the compressor, so I guess it's time to use the warranty.
Let us all know the outcome Thumbs Up
Post #650020 Wed Oct 01 2025 10:08am
Clarkie2488
Will do, its going in on the 14th, so it will be a while. Cheers Stewart
Post #650021 Wed Oct 01 2025 10:14am
