![]() | Home > Maintenance & Modifications > Cone filter/airbox delete |
| NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 520
Downside is they’re usually oil media which kills MAF sensors.
| RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9155
My question too - the turbos share an air filter and that's it. Once the air is on its way to the compressor it's separate and once it's gone through the compressor then the air filter is irrelevant. How would the air filter change the outcome of a turbo failure?
| L320.tdv8 Member Since: 19 Sep 2025 Location: Lincoln Posts: 4
Ive purchased 2 quality air filters that are not oil saturated for filtering so shouldn't kill the maf.
| 41jules1967 Member Since: 01 Jun 2025 Location: Leeds Posts: 150
This seems very odd. The direction of airflow is filter down to turbo. There should be no way for air to flow back. I thought the turbos on the TDV6 are below the level of the airbox so oil couldn't flow down either.
| Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 472
If one turbo has failed and is not spinning but leaking oil the working one will blow air "the wrong way" thought the bad ,stalled turbo and up into the airbox. Always listen to old people or when they die you will live on in ignorance.
If they're plumbed that way, then presumably there's no way to separate them for 2 separate intakes? 2021 L494 D300MHEV Autobiography
who knows mine is a 2.7 Always listen to old people or when they die you will live on in ignorance.
They meet at the air filter box. So if one thought the oil blowing back issue was a thing, taking the filter box off and giving 2 separate filters would avoid that. The usual thing is that the blown turbo dumps oil in to the intercooler and whilst the intercooler is set up to flow the two sides separately (two intercoolers in one housing), it's possible for oil to get between the two, I seem to remember. As cone air filters are quite big, usually, I wonder if there's enough room in the space currently housing the filter box to put in 2 cone filters. The MAFs are immediately outside the filter box and fitted to preformed elbows so some new pipework will also be required in order to both position the filters and house the MAFs. I can see one of the filters being place low down which could put it at risk of ingesting water (the engine bay not being a sealed environment) if someone drove through deep water. An interesting exercise even though I'm not convinced that the OPs reason for doing it is correct. Would be interested to see photos of the install, however. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
I fitted the 2 cone filters. If you unbolt the mafs from the air box the maf has a lip that is perfect for a 70mm air filter to fit straight on to so no additional pipe work ir required and they fit with just the air box lid removed. I do need to make some sort of bracket to keep them from wobbling and keep them further apart but that's not a big task
That fits more easily than I imagined it would - I was thinking about the cone filters that have wide bases like they used to sell in Max Power back in the day |
