![]() | Home > Technical > Battery voltage |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5134 ![]() ![]() ![]() |
I recently changed my battery which was a Varta AGM and it had been on the car for nine years, then only changed it as low battery warning was showing occasionally, plus the car has never had a flat battery in the 12 years I have owned it although I do use a ctek charger.
RallyeSport Member Since: 20 Jun 2024 Location: Gloucester Posts: 100 ![]() ![]() ![]() |
Hi Col,
I can't really remember but I think that's about the voltage my gap tool shows when connected without ignition on, I did try and fit a 020 battery but it was to much of a squeeze to get it in the space as was forced up against wiring and a ecu if I remember correctly, as it is around 40mm longer than the 019, not sure if the space on a S/C is smaller though, as there is a second air filter where the FBH is on the diesel, but wouldn't think it is though, although I do believe some have fitted the 020 on one or the other.
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 511 ![]() ![]() ![]() |
Your idle voltage seems low in my opinion. Mine pushes 14.7 shortly after startup at idle and drops to around 14v after driving a bit. Granted mine has the BMS system, but high 13’s still seems low. My Varta AGM is 4.5 years old and still shows 12.4v to 12.6v after sitting overnight. I do not use a battery tender/charger on it. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
The voltage at idle I’ll check again the weekend, that was a guesstimate to be honest, I know the charging system is ok.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9139 ![]() ![]() ![]() |
Ideally you should check the battery when it's entirely shut down as opening the door to plug in the IID will wake up all of the ECUs and give a seemingly low voltage. Do you have tow electrics? You can check through the plug if so as it has a permanent live and earth supply - that's how I check mine. Alternatively, Ctek leads connected to the battery and left for a while after it's locked and then checked with a multimeter.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5124 ![]() ![]() ![]() |
Avoid Exide
