![]() | Home > In Car Electronics > TST Instrument Cluster Retrofit |
Timmo1710 Member Since: 16 Jun 2025 Location: United Kingdom Posts: 11 ![]() ![]() |
Where can it be purchased from?
Amazing, did you build it your self or buy it already made? |
Dutchviking Member Since: 04 May 2015 Location: Oslo Posts: 9 ![]() ![]() |
you mean there is a similar gateway under development and is almost completed? 4 CAN tranceivers, and a CPU that does the CAN ID mapping? How will it solve the VIN, milage and security? Need SDD? |
icemania Member Since: 14 Sep 2025 Location: Sidney Posts: 5 ![]() ![]() ![]() |
You don't need an SDD for installation. You just need to download the CCF configuration from the car or copy the eeprom from the dashboard and load it into the adapter. Here's the installation in a Discovery 3 with a 4.0L gasoline engine.
TheWojtek Member Since: 08 May 2015 Location: PoznaĆ, Poland Posts: 750 ![]() ![]() ![]() |
Oh man, do I see a prefacelift L319 with facelift exterior and facelift RRS interior? Impressive upgrade. Regards etc.,
Yes, the interior is an L320, but the exterior is a Discovery 4. |
Test rig working
BCM, PCM - L320 2010+?
Well yeah, that is the whole point. It can, but needs a CAN translator which I am putting together. This is the rig I will use to read and test CAN messages |
