![]() | Home > Technical > Cr*p Quality parts 3.0L V6 diesel |
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 466 ![]() ![]() ![]() |
JB weld good as new Always listen to old people or when they die you will live on in ignorance.
erickwan Member Since: 27 Mar 2016 Location: P Jaya Posts: 148 ![]() ![]() |
Not sure how much JB Weld can tolerate tropical temperatures |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 508 ![]() ![]() ![]() |
Not the first I’ve seen, seems more common on the early 3.0’s. They’re 2.7 parts carried over and were updated in later years. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
If the throttle body & duct are carry overs from the 2.7L, they are probably not strong enough to handle the higher temperatures and pressures of a twin turbo 3.0L |
Pretty much it. Like I said, they were updated later and aren’t as problematic. So if you buy a new one for the gosh awful price they ask, it will be the updated version.
JB weld OK for all under bonnet situations inc repairing cracked inlet manifolds ...dont you watch your LR time ? Always listen to old people or when they die you will live on in ignorance.
41jules1967 Member Since: 01 Jun 2025 Location: Leeds Posts: 120 ![]() ![]() |
it's 14 years old, plastic and has lived through thousands of heat cycles. Not entirely surprised it's failed. Wait until you hear about the inlet manifolds! Sold my Jaguar when they went.
It's the plastic welding that broke, not the actual body. The weld was not even consistent all round the plastic flange, hence "cr*p" |
I think the term is 'fit for purpose'. After all, it worked perfectly for well in excess of it's design life.
