![]() | Home > General > Accepting deposits - L320 Backseat map light kits |
| NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 520
Deposits are now being accepted. PM for further depails.
| T Member Since: 18 Feb 2024 Location: Isle of Wight Posts: 106
It's something I've been wanting to do too for ages, but it's just become another item in my box of roundtoits.
You do not need to drop the headliner at all. You will need to pull away the right hand side inner rear pillar trim and the rearmost part of the inner quarter panel (not fully remove) for access to run and secure the wires. You will also need to remove just the upper part of the tailgate seal to get the wires to the light openings. It’s a very straightforward job that you don’t need much more than something to remove the backseat map lights and cut the ends of zip ties (included). I’ve done my best to make the install as easy as possible so just about anybody can do it without any major fiddling.
OK, that sounds fine to me. I'm up for a set - thanks for clarifying. |
| RallyeSport Member Since: 19 Jun 2024 Location: Gloucester Posts: 112
Id be interested, do you have any photo's of the install and what components are included with the kit? |
Right this moment I do not have install photos, but I will when or before these actually ship, in fact possibly a video. The light kits I have done have had different modifications done to make them work. The kit lights will have a similar, yet different modification done to them to add a third pin in the middle (this is why new lights are included). The wiring loom takes care of the remaining changes you’d otherwise have to make with the pins and adding diodes.
| TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 752
Courtesy of @NoExpert I got the early prototype of this kit in my L320 and I can assure you all, it might not seem like a big deal for the driver, yet it is a gamechanger for the passengers, finally able to embark and disembark safely from the rear seats. Your grandma will appreciate this kit (think of the inheritance from a grandma that is happy with you), your kids will too. Regards etc.,
I look forward to getting this fitted, so just PM me with your bank details etc. when you want the money.
| Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 427
I think what NoExpert will provide is excellent and what LR should have provided when the cars were sold.
I looked up some postage prices and have added them, but I’ve learned the calculator can be way off from reality.
Deposit sent. |
And received. Thank you T.
| keltick Member Since: 22 Apr 2025 Location: New Orleans Posts: 1
I'd definitely be interested in the expanded kit. |
@keltick, responded to your PM on the other site. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
| All times are GMT |
