Home > General > Leaking ACE block
Salisburylander
2011 Range Rover Sport 3.0 TDV6 HSE Bali Blue
Leaking ACE block
The photo appears to be upside down but one can get the gist of the story!
The ACE fluid has been leaking really badly. I’ve just had a good look and cleaned some of the fluid off around the area. It would appear that it is not the pipes that are leaking, although some are quite corroded; but the large nut on the block itself.
Does anyone know if this is some kind of filter and requires an O-ring?
Post #649670 Fri Sep 05 2025 1:07pm
Salisburylander
A quick search around the interweb and a service kit which includes new filter and O-ring can be purchased.
I’ve lost so much fluid that I just need to purchase more ACE fluid now.
Post #649671 Fri Sep 05 2025 1:36pm
Lrstaylor
United Kingdom 2006 Range Rover Sport Supercharged Bali Blue
Iv never yet found an Internet or ebay filter to fit they all seem to be for earlier discovery models.
The O rings however have fitted. Often the screw in plug is damaged by some previous monkey fisted person. As the filter is metal a quick blast of carbon cleaner will sort yhat. Some on here have used ptfe tape on the treads as well.
Good luck
Post #649672 Fri Sep 05 2025 2:10pm
Salisburylander
The vendors of filters all say “suitable for Discovery 2 and all RRS models 05-13”, but like you say, at least I can use the large O-ring and give the existing filter a clean if necessary.
I’ve ordered items that are now in the post. I’ll let you know next week if I was successful.
Post #649673 Fri Sep 05 2025 2:19pm
Disco_Mikey
You'll probably find that the aluminium has reached with the steel, and corroded away
Look closely, you'll see the o-ring poking out underneath the plug...
Post #649674 Fri Sep 05 2025 7:22pm
Salisburylander
The parts might turn up on Monday so I’ll be able to take the plug out for inspection.
Post #649676 Fri Sep 05 2025 8:09pm
Lrstaylor
https://www.rrsport.co.uk/forum/topic62392.html
Post #649677 Fri Sep 05 2025 9:28pm
Salisburylander
Thanks for the info. All the ones for sale seem to have the larger band on each end. Like you mentioned, I might just be using the O-ring and flushing the old filter out…
From your previous link, one chap’s method of sorting out the ACE problem out was to purchase another vehicle…yikes!
Post #649679 Sat Sep 06 2025 9:11am
Salisburylander
Update:
Both new and old filters are labelled as Delphi. They are both the same size at approximately 63.5mm in length.
The O-ring on the nut was flat and slightly chewed up but the damage may have been caused by undoing it in the first place. The O-ring is 30mm ID and possibly 2.5mm thickness. I found it slightly difficult to measure the thickness.
The whole job took about 5 minutes and I also wrapped a small amount of PTFE tape on the thread prior to refitting the nut. The nut requires a 38mm socket to remove and tighten it. A quick top-up with fluid and it was good to go.
Post #649715 Mon Sep 08 2025 5:30pm
