![]() | Home > General > Leaking ACE block |
Salisburylander Member Since: 16 Mar 2014 Location: Salisbury Posts: 256 ![]() ![]() |
A quick search around the interweb and a service kit which includes new filter and O-ring can be purchased.
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 357 ![]() ![]() ![]() |
Iv never yet found an Internet or ebay filter to fit they all seem to be for earlier discovery models.
The vendors of filters all say “suitable for Discovery 2 and all RRS models 05-13”, but like you say, at least I can use the large O-ring and give the existing filter a clean if necessary.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4531 ![]() ![]() ![]() |
You'll probably find that the aluminium has reached with the steel, and corroded away
The parts might turn up on Monday so I’ll be able to take the plug out for inspection. |
Thanks for the info. All the ones for sale seem to have the larger band on each end. Like you mentioned, I might just be using the O-ring and flushing the old filter out…
Update:
