![]() | Home > Technical > 3.0 SDV6 |
41jules1967 Member Since: 01 Jun 2025 Location: Leeds Posts: 102 ![]() ![]() |
If i had to use one word - then like so many criticisms of JLR products - overhyped.
benny4x Member Since: 04 Sep 2025 Location: somerset Posts: 3 ![]() ![]() |
Thanks.
T Member Since: 18 Feb 2024 Location: Isle of Wight Posts: 89 ![]() ![]() ![]() |
I bought mine eighteen months ago and although I've had to keep spending on it, I wouldn't change it for anything other than another one. Hopefully, another £2,000.00 I'm about to spend on it will be the last for a while.
Well, I'm buying it from a specialist land rover dealer/repairer He is doing a main service and fresh Mot and 3 months warranty with him. S o hopefully i should be sound at the moment. Of course warranties are hard to come by for vehicles of this age. |
BrickBox Member Since: 01 Sep 2025 Location: At the petrol station ⛽️ Posts: 2 ![]() |
It definitely is overhyped, but it is a concern… unfortunately. Service it, warm it up and cool it down properly. You should be fine. L494 SVR
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9128 ![]() ![]() ![]() |
It's an issue just like the older 2.7TDV6 had an issue with crank bearings spinning. Did/does it happen? Yes. Is it as common as reading forums/problem pages/youtube/etc., would have you believe? No. Is there anyway to tell if a particular vehicle is going to fail? No. Just you either go with it and try not to worry or you go elsewhere.
Johnrrs Member Since: 16 Feb 2021 Location: Yorkshire Posts: 481 ![]() ![]() ![]() |
Had mine for over 8 years and still loving it and don’t want to replace it with anything else as nothing else compares to it in my personal option. I knew nothing about the crankshaft issue with this engine until a year in and read all the horror stories online It made me get an aftermarket warranty just in case the worst happened. I cancelled the after market warranty last year as the premium doubled to almost £2K . I get mine serviced every year at MOT time and as it’s a 3rd car it does about 4000 miles per year if that but still gets serviced as per LR schedule. It also goes to a LR specialist who came recommended on this forum and they certainly know everything about these vehicles. Like everyone says on here keep it well serviced and done at a specialist and enjoy the car and don’t worry about what could happen. If you google any car these days you probably wouldn’t buy any of them as people only talk about the bad things not the good things |
