![]() | Home > General (L494) > Land Rover fluids/oils recommended |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5150 ![]() ![]() ![]() |
Do you have a open rear diff or a electronic locking one ? as they use a different spec oil in each.
Brian525177 Member Since: 01 Sep 2025 Location: Oregon Posts: 7 ![]() ![]() |
Should be locking. Not sure |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1210 ![]() ![]() ![]() |
If you have Dynamic mode, then it's a locking diff.
naks,
Dynamic mode means that it has the ETM version.
got it
help me understand where can I find "the 4x4 information screen" Also, which bottle of two options above is right? |
IIRC, you access it by selecting the "4x4 Info" button on the touchscreen home menu.
I have locking. There are two locks on the screen - dif and transfer case. I found one more bottle LR019727 - this one is from LL and I trust it more than Castrol, Atlantic British shows that it fits my vehicle. Any thoughts on it? ![]() Choose oil is a trouble. Overall, I'm frustrated with LR - I cannot even find how many horse powers, torque, what the engine is, and other tecnical info using VIN. I had BMW and this was not an issue |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9151 ![]() ![]() ![]() |
a local dealer sent me my car's built sheet and it shows "Rear Axle Differential - Torque Vectoring By Braking (TVBB)"
BrickBox Member Since: 01 Sep 2025 Location: At the petrol station ⛽️ Posts: 2 ![]() |
Locking - the red padlock shows it’s locked. L494 SVR
