![]() | Home > Technical > RRS 2010 3.0 td6, ARC bar advice needed. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9115 ![]() ![]() ![]() |
Sounds like someone telling you the absolute worst news possible and the associated big bill in order to have you set up for the big bill he then gives you.
Rick08 Member Since: 20 Jul 2025 Location: Yorkshire Posts: 3 ![]() ![]() ![]() |
I can’t speak on the integrity of the mechanic, I have only used them once before. They carried out a new timing belt replacement and full service.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5122 ![]() ![]() ![]() |
The pump /system has a operational pressure of up to 165bar = appx. 2300psi I don't think a pressure of 20psi to bleed the system is going to make a pipe leak or burst.
Right ok, that’s a lot more than 20psi lol.
Use this link from member "naks" it will take you to a site where you can download a workshop manual, even if you are not mechanically minded it may give you a bit of a heads up on things for the next time, and there will be a next time. |
