gogsy1956
You cannot just throw gas at it and hope for the best,, you have to put in a measured amount to suit the system. The system charge is on a sticker on the slam panel under the bonnet,,, too much and it won't work. 810g sounds about right for a dual system ( front and rear),, whereas front system only is about 650g. The only way to charge it correctly is to vac it down then recharge with the correct amount,,, but check first as to what is required. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
