![]() | Home > General (L494) > Trim removal |
| Grimble Member Since: 21 Aug 2020 Location: Staffordshire Posts: 278
Hoping for some advice here so I don't break anything
| tygelert Member Since: 28 Sep 2022 Location: Logan Utah Posts: 1
Did you get a fix for this as I have the same leaks on both sides. |
Not fixed yet, seems to be worse when the weather was much colder. Advice generally points to the drain pipes on the sunroof, but as yet not had a chance to remove the roof trim. I'm a bit scared of snapping all the clips. RRS HSE Dynamic SDV6 2014
| Karlp606 Member Since: 25 Jun 2022 Location: East Yorks Posts: 321 |
That is your sunroof drains, they will have rusted off. The rainwater will berunning backwards into the boot and into that area, thats where mine was damp inside and traced it back to the sunroof drains rusting off, now all fixed but you need to check this out asap as it could start leaking under the passenger seats. |
How did you fix the drains? Any advice appreciated. RRS HSE Dynamic SDV6 2014
So you need to check the drain tubes are still secured to the drain holes, you need to take the rubber door seal off the around the door frame where the rear seats are , you can the pull headliner down and check you should be able to fit your hand in and see/feel the rubber drain tube just check it is securely attached to the drain nipple from the sunroof, if it feels crusty and loose then its come away with corrosion.
link here
and a thread I started here
Thanks for all the advice and the links, although in my experience trim never just 'pops off' without snapping clips. Any guidance on a technique for the strips alongside the sunroof? RRS HSE Dynamic SDV6 2014
The clips on the sunroof are different to interior clips, the sunroof trims push down onto a fixed screwed in clip so you can really snap them, you need a plastic trim removal tool, stick it under the rubber gasket then turn it 90 degrees keep doing this along the black plastic trim and it will all just pop off.
| rivet Member Since: 09 Jun 2025 Location: Nor'east Posts: 24
Pardon my question
The trim piece on the internal D pillar should clip back ok, even the screw behind the airbag badge locates easy enough. Had the external roof trim off a couple of times, comes off with a frightening sound but does go back ok. Necessary in order to repair he drain lines. The drain tube design is very poor, shame on you LR. RRS HSE Dynamic SDV6 2014
Thanks for the response.
Dont worry, this roof trim can be removed by your fingers. Its retained by a number of metal 'wedges' along the length of the strip. Just open the sunroof fully to get a good grip. Feels wrong when taking it off, but it goes back fine. You are correct, this must be removed for a visual inspection or repair. RRS HSE Dynamic SDV6 2014
