Home > General (L494) > Trim removal
Grimble
Trim removal
Hoping for some advice here so I don't break anything
I have a leak from the join in two parts of internal trim. Water is coming out of the join in the area just below the red line in the pic.
Passenger side, rearmost pillar (the rear hatch).
First thing I think is to remove the angled trim part.
How does this come off? Straight pull away towards the centre of the boot or something else?
Do I need to get some replacement clips on order as I don't have a lot of faith in plastic trim clips, especially in this cold weather.
Any advice much appreciated. RRS HSE Dynamic SDV6 2014
Nemo mortalium omnibus horus sapit
Post #630229 Wed Jan 25 2023 4:04pm
tygelert
United States 2013 Range Rover Sport Supercharged HSE Orkney Grey
Did you get a fix for this as I have the same leaks on both sides.
Post #633045 Sun May 14 2023 8:08am
Montipora
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Santorini Black
I had same fault, was fixed by replacing the sunroof drain tubes and a replacement of a clip that was on a technical bulletin from JLR, not sure what the clip was or does as it was sorted under warranty
Post #633050 Sun May 14 2023 10:32am
Grimble
Not fixed yet, seems to be worse when the weather was much colder. Advice generally points to the drain pipes on the sunroof, but as yet not had a chance to remove the roof trim. I'm a bit scared of snapping all the clips. RRS HSE Dynamic SDV6 2014
Post #633081 Tue May 16 2023 11:30am
Karlp606
Re: Trim removal
That is your sunroof drains, they will have rusted off. The rainwater will berunning backwards into the boot and into that area, thats where mine was damp inside and traced it back to the sunroof drains rusting off, now all fixed but you need to check this out asap as it could start leaking under the passenger seats.
Post #633194 Fri May 19 2023 10:49am
Grimble
How did you fix the drains? Any advice appreciated. RRS HSE Dynamic SDV6 2014
Post #633197 Fri May 19 2023 11:34am
Karlp606
So you need to check the drain tubes are still secured to the drain holes, you need to take the rubber door seal off the around the door frame where the rear seats are , you can the pull headliner down and check you should be able to fit your hand in and see/feel the rubber drain tube just check it is securely attached to the drain nipple from the sunroof, if it feels crusty and loose then its come away with corrosion.
You need to fit a new grummet or a nut with a head through the original drain hole, seal it and attach it to the drain tube, its a straight forward job but a PIA with the headliner.
Check this thread out here - sorry its on another forum me and a few other guys mainly in the US have done some repairs to reseal/renew the drain holes.
BTW there is no official fix for this, JLR say its a full new sunroof as the drain nipple are apart of the sunroof cassette frame! £5-6k!
Post #633198 Fri May 19 2023 11:40am
Karlp606
link here
https://www.rangerovers.net/threads/sunroo...ge.351767/
Post #633199 Fri May 19 2023 11:41am
Karlp606
and a thread I started here
https://www.rangerovers.net/threads/have-y...st-2393113
Its a hugely common issue and porbably 60-70% of owners dont know its happening until the amp blows under the passenger seat as thats where the water usually goes.
Post #633200 Fri May 19 2023 11:44am
Grimble
Thanks for all the advice and the links, although in my experience trim never just 'pops off' without snapping clips. Any guidance on a technique for the strips alongside the sunroof? RRS HSE Dynamic SDV6 2014
Post #633266 Mon May 22 2023 11:16am
Karlp606
The clips on the sunroof are different to interior clips, the sunroof trims push down onto a fixed screwed in clip so you can really snap them, you need a plastic trim removal tool, stick it under the rubber gasket then turn it 90 degrees keep doing this along the black plastic trim and it will all just pop off.
Stick a microfibre cloth over the metal part of the car that runs above the doors as you do it to stop any scratches.
Post #633279 Mon May 22 2023 3:50pm
