![]() | Home > General (L494) > My SVR Story (picture heavy!) |
philmw Member Since: 18 Aug 2006 Location: Nottingham Posts: 1690 ![]() ![]() ![]() |
Engine oil is every 12 months/16K miles
41jules1967 Member Since: 01 Jun 2025 Location: Leeds Posts: 142 ![]() ![]() |
So my point was what was the average mileage between changes.
Just under 12k a year. |
Doesn’t sound excessive.
There were problems with tensioners apparently (piston wearing a hole in the aluminium tensioner), but was 'fixed' in 2013 with a steel insert. Mine's a 2015 car.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5150 ![]() ![]() ![]() |
I did read somewhere they introduced a second upgrade/improvement to the timing chain tensioners etc. but I don't know if that is correct or what year/vin no. it was supposed to have been introduced. They originally changed the tensioner plungers from aluminium to stainless steel due to excessive wear.
gt40 Member Since: 21 Sep 2015 Location: Cape Town Posts: 7 ![]() ![]() ![]() |
The 2013 modification was an intermediate fix and only changed the design of the tensioner plunger - the dimensions and shape of the body of the tensioner remained the same. In late 2014 / early 2015 the tensioner was completely redesigned as was the moveable guide rail which included the steel button. There has been a further change since then but I think it must have been some internal change to the tensioner because it looks identical from the outside. |
Thanks.
I wouldn't know if they have changed the tensioner lever, but the part number is still the same as the original modified one on the right introduced in 2013, I would have though if the lever had changed again it would be a different number, although the actual tensioner has changed number several times.
The tensioner lever/guide shown on the right of your photo was only introduced in 2015. The 2013 update used the same guide as the one on the left but used the modified plunger shown in the photos below.
That is a little confusing really as the tsb say's the issue was wear on the timing chain lever although it did say to replace the tensioners as well, if they didn't modify the levers it was never going to prevent the same problem reoccurring, although the part number listed in the tsb for the lever is still the current number. I did however look at a early L/R microcat parts list and it shows the new type lever was not fitted untill a much later Vin No. than the one shown on the original tsb.
One needs to look at the engineering number on the guides themselves to see the difference between the old, intermediate and new. I have a box of them somewhere in my workshop from replacement jobs I have done over the years so will dig them out and post a couple of photos.
New oil pump and sprocket, and eight new injectors added to the repair. No new cam shafts. |
I have attached 3 photos. Number 1 is the original INA guide -engineering Number 8W93-6L226-CB. Number 2 is the intermediate guide - engineering number 8W93-6L226-CD which happened sometime in 2013. Number 3 is them side by side and one can see the different wear pattern due to the different plunger end between the original and intermediate design. One can also see the difference in the bearing portion of the 2 guides. The intermediate guide is slightly wider to accommodate the wider tensioner plunger. (note there is no steel button on either. The steel button only came with the third design that most people know about). I actually thought that the original and intermediate guides were the same but there are clear differences. I hope that helps clarify. ![]() ![]() ![]() |
