Home > General > Security - steering lock
scrumps
41 jules,
Don’t forget the GHOST has to be set up with a laptop when installed.
The “learn loop” on the unit is then cut so the config is set (unless a new loop I soldered in and the unit reconfigured).
I was nosy when mine was fitted (as Chartered Electronics engineer) so the fitter was really good at showing me what was possible.
It could be a config issue - or you could try re-pairing your phone(s) using the code on the card you should have been given when it was fitted.
Scrumps Somerset - Where the apples do grow and the cider do flow!
2021 Defender 90 D250 HSE in Tasman with white roof.
24MY D300 AB - Verasine Blue - 😀
19MY SDV6 AB - Byron Blue - Gone
17MY D5 SDV6 HSE - Firenze Red - Gone
16MY SDV6 AB -Aruba Silver - Gone
13.5MY SDV6 "HSE Black" - Baltic Blue - Gone
10MY TDV8 HSE Galway Green - Gone
14MY D4 HSE in Scotia Grey - Gone
05 TD5 D90 CSW in Cairns Blue
Post #649222 Fri Aug 01 2025 3:39pm
41jules1967
My fitter wouldn't let me see it - it was all very secretive so I've no idea what a ghost looks like or even where it's fitted in my cars!
Good idea though, I might try pairing my RRS with my phone - if it works reliably then I could do away with the tag which would make it a bit more secure. I generally have my phone with me all the time anyway. 2021 L494 D300MHEV Autobiography
2019 Discovery Sport D180 HSE
Post #649223 Fri Aug 01 2025 4:36pm
Ironhorse
Big yellow bar through steering wheel didn't stop toe-rags from trying to have mine away, smashed window sawed through steering wheel to remove yellow bar, cap off OBD port but didn't get away with car,was only the ghost that saved them getting away with it
Also Had a ghost fitted to wifey evoque, would recommend every time
£1200 for new wheel
I won't be putting a steering lock on anything else 2014 L494 5.0 SC
2014 L538 2.2 SD4
Post #649228 Fri Aug 01 2025 7:29pm
Golan
United Kingdom 2013 Range Rover Sport SDV6 HSE Bonatti Grey
Side step from the “Ghost” convention but as I mentioned earlier I have the large bendy yellow Stoplock as I thought that the visual deterrent was a good idea.
As said earlier if they’re determined to steal it they will so making your car less appealing than the over one parked down the road could be the way to go.
Anyhoo after seeing the “Powerful” gear knob lock I ordered one straight away… It arrived today and it’s very yellow and very well made and I bet it would be an absolute bastard to get off so it’ll be replacing the Stoplock.
Hopefully that and my 2 AirTags will mean I get to hang onto my RRS
Post #649243 Sat Aug 02 2025 5:34pm
skid1963
Maybe i should speak to Powerful about some commission Laughing 2015 L494 SDV6 3.0 HSE Loire Blue
2006 L320 4.2 Supercharged - Gone
2009 BMW X5 M-Sport - Gone
2007 L320 2.7TDV6 SE Buckingham Blue - Gone
2011 Jaguar XFS 3.0V6 Diesel - Gone
2009 (59) L320 Facelift 3.0TDV6 HSE White Wrap - Gone
2008 BMW X5 M-Sport - Gone
2005 Audi A6 3.2V6 Quattro S-Line - Gone
Post #649244 Sat Aug 02 2025 5:48pm
Golan
So I've been playing this morning Very Happy
I tried out m new "Powerful" Gear Lock and I'm very happy with that and I also fitted my new "Brodit" phone holder.
I've never had a proper phone holder, again very happy with it. It's made to measure and fits like a glove with no movement.
I'm hoping it'll fix another problem I've been having, I fitted a AndroidAuto/Carplay system a few months ago and it has this annoying habit of resetting every now and then my thoughts are that because I just lay my phone on it's back in the cup holders the "auto-rotate" might be upsetting the Carplay so standing it up in a holder should stop that plus after a bit of reading it seems that the phone works best when in the upright/portrait position so fingers crossed.
Post #649246 Sun Aug 03 2025 11:09am
Ironhorse
gearstick lock looks spot on to be fair
nice bit of kit Thumbs Up 2014 L494 5.0 SC
2014 L538 2.2 SD4
Post #649278 Mon Aug 04 2025 8:44pm
