![]() | Home > General > Parking brake fault on 2017 RRS |
| glendmc Member Since: 10 Mar 2024 Location: 44 Posts: 40
Hi you all, i am having the same problems after changing my rear brakes and calipers i get these on my dash, PARKING BRAKE FAULT, PARKING BRAKE NEEDS CALIBRATING, i tried to erased the code however that did not work, what could be the problem and how to fix it? |
| Rjgordon0 Member Since: 25 Jan 2024 Location: Halifax Posts: 11
Hi, there is a sequence to calibrate the parking brake. Hold the brake pedal. Press & hold the brake pedal while pressing the parking brake button. Hold for 10-15 seconds until you hear the EPB motor operate or feel the brake engage/disengage. Turn the ignition off & on again to see if the fault warning clears. |
Thank you for your effort,however i tried that method and it did not work,another method was given to me that the actuator might be at fault,i will check to see if i have a loose connection on the actuator and post the result. Thanks again |
Here is an update on PARKING BRAKE FAULT, like i said i saw this on ...... the problem was the EBA,
| Grimble Member Since: 21 Aug 2020 Location: Staffordshire Posts: 278
I recently changed my rear discs and pads and struggled to get the plug to seat in the socket of the parking brake actuators. It took a lot of effort before the retaining clip would lock into position. I appreciate it needs to be water tight, but a softer rubber seat would still do the job. RRS HSE Dynamic SDV6 2014
Sure would,but LRJ won't make it any easier for us. |
