Home > General (L494) > HVAC error code
glendmc
Jamaica
HVAC error code
Hi you all, i am still trying to find the answer as to why my air con. not blowing cold air, my OBD2 reads
Error code B13C2-49(windshield misting sensor) can anyone explain to me if this is tied into the air con unit, what does rain sensor have to do with air con or should i just ignore this reading?
Post #649163 Tue Jul 29 2025 6:13pm
Notyalc
Watching.
I have the same fault code but ice cold LHS not as cold RHS. Wondering if i need a re gas?
Pressure is around 800 KPA
Post #649165 Tue Jul 29 2025 8:21pm
glendmc
Jamaica
Thanks for that information, i just took that windshield sensor out just to check,i just can't see it having anything to do with the AC, if anyone else gets that code and their AC still runs fine please let me know.
Salud
Post #649166 Tue Jul 29 2025 8:32pm
2 RRS
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Bourneville
The windshield misting sensor monitors moisture content in the cabin at windshield level and if detected, directs air to the inner of the glass to clear it. It will not stop the ac blowing cold and the system can work perfectly with it in fault. Only fix for this common fault is to change the sensor.
What engine do you have and does the HVAC blow hot both sides if on full heat?
Post #649174 Wed Jul 30 2025 4:48am
glendmc
Jamaica
Thanks or that, the engine is 3.0 TDV6 and yes from both sides, it is not blowing heat(hot air) it is not blowing cold air its like outside temperature, if outside is cool it blows cool however its very hot like it is now it blows very hot air. To go a little further when i start the car up in the garage at first it blows cool air but minutes later it goes away and just normal air coming out the vents, it is like something is stopping the freon from getting cold or the compressor even though running is not running at max,but why no other fault code shows up on the OBD2 scanner for HVAC other than windshield intermittent wiper sensor? thats strange.
Post #649188 Wed Jul 30 2025 8:22pm
2 RRS
I was going to say if it was the 4.4 with a fuel burning heater that it's likely to be the diverter valve on the FBH, I think most 3 litre's didn't have th FBH unless spec'd as an option when new. I had a very similar thing on my 4.4 L405 and it was the diverter valve.
Post #649199 Thu Jul 31 2025 11:14am
