![]() | Home > My Range Rover Sport > Transmission fault HDC fault |
daxmatt Member Since: 16 Aug 2014 Location: kent Posts: 220 ![]() |
have a look on the 4x4 info screen, do the wheels move when you turn the steering wheel ? |
Adey69 Member Since: 23 May 2025 Location: Leicester Posts: 5 ![]() ![]() ![]() |
Yes the wheels turn perfectly when I turn the wheel |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9139 ![]() ![]() ![]() |
Serious suggestion: check the brake lights. Blown brake light bulbs have been known to throw up a cascade of failures (because the HDC system uses the brake lights, a failed brake light prevents HDC which then throws up errors in systems that talk to HDC).
I did notice last night when I checked if the wheels on the screen moved when I turned the steering wheel that it happened when I touched the brakes so good call I will check the brake lights today
Devon Z Member Since: 22 Sep 2019 Location: Brixham, Devon Posts: 321 ![]() ![]() ![]() |
+1 for checking brake lights, my gearbox went into limited gears and no manual change turned ont to be brake light bulb had been arkin and had burned the bulb holder, couldn’t get the bulb out. Steve
Thanks for all the advice
Yes that too, I keep a spare in the glove box. Steve
Glad it was a simple resolution. |
