Home > My Range Rover Sport > Transmission fault HDC fault
Adey69
United Kingdom 2009 Range Rover Sport TDV6 HSE Santorini Black
Transmission Fault
HDC Fault
Gearbox fault,
Parking break fault
Suspension lowered but Not indicated in the 4x4 info screen
All came up in the message centre.
Yellow warning lights too.
Any ideas what this could be no loss of power just lose cruise control and suspension goes a bit harder.
Plugged a DTC reader in nothing showing current or historic
Thanks for any help guys
Adey
Post #649161 Tue Jul 29 2025 6:08pm
daxmatt
have a look on the 4x4 info screen, do the wheels move when you turn the steering wheel ?
Post #649162 Tue Jul 29 2025 6:13pm
Adey69
Yes the wheels turn perfectly when I turn the wheel
Post #649164 Tue Jul 29 2025 7:53pm
Serious suggestion: check the brake lights. Blown brake light bulbs have been known to throw up a cascade of failures (because the HDC system uses the brake lights, a failed brake light prevents HDC which then throws up errors in systems that talk to HDC).
Loose earthing point. There are several around the car particularly in the engine bay and front wheel arches.
Battery/alternator dying. Low electrical power / electrical quality causes all sorts of issues with these vehicles because there are so many ECUs. 2012 SDV6 - it's missing a couple of cylinders
Post #649171 Tue Jul 29 2025 11:16pm
Adey69
I did notice last night when I checked if the wheels on the screen moved when I turned the steering wheel that it happened when I touched the brakes so good call I will check the brake lights today
Thanks
Post #649175 Wed Jul 30 2025 7:24am
Devon Z
England 2005 Range Rover Sport TDV6 HSE Java Black
+1 for checking brake lights, my gearbox went into limited gears and no manual change turned ont to be brake light bulb had been arkin and had burned the bulb holder, couldn’t get the bulb out. Steve
2005 2.7 TDV6 HSE, ongoing project.
1998 Volvo V70 R auto FWD, Back on the road again.
1999 BMW Z3 (owned from new) garage queen.
Post #649178 Wed Jul 30 2025 9:09am
Adey69
Thanks for all the advice
It turned out to be the brake light switch changed that and pop all works as it should
Post #649180 Wed Jul 30 2025 12:57pm
Devon Z
Yes that too, I keep a spare in the glove box. Steve
Post #649184 Wed Jul 30 2025 3:56pm
Glad it was a simple resolution. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #649186 Wed Jul 30 2025 6:37pm
