Home > General > Desperate! Oil starved, does 2.7 HDI bottom end fit tdv6?
dafrog
France 2006 Range Rover Sport TDV6 HSE Java Black
Well, I'm new on the forum and I've been trying to get answers and help, before getting into the thick of things. I live on a remote island, near Mauritius, a french overseas region island called Réunion Island and I totally love Range Rover. Here's the story :
I've had, 3 times, crankshaft issues. First and second because of the oil pump that was changed, then, because of water getting into the bottom end... So, to make a long story short, I repaired it and the car was running great in my backyard. so I decided to get her out for a gentle ride, before getting everything together. Drove for about 8 kms, then a smell of oil appeared, I thought it was the oil on the engine after the repair, then smoke came. I stopped and there was no leak. And by the time I got home, there appeared a rattle (back to when I had repaired it) and checking the oil level, it was completely empty and the engine rattling. So Someone is selling a 2.7 HDI engine. Just wanted to know if the innards are the same (apart from the turbos) and if I could use the bottom end and some parts to get my RRS back on the road. Thanks for your response.
Post #648821 Mon Jul 14 2025 1:40pm
the bolt pattern between the engine block and gearbox are different.
so you can't use the block
Post #648823 Mon Jul 14 2025 4:05pm
dafrog
Thanks Andy. But could I use the crankshaft only, then? Mine didn't spin in. But the conrod bearings must have been ruined in the process.
Post #648824 Mon Jul 14 2025 4:57pm
maybe. I don't know.
Jaguar engines are closer to the landrover
You need to understand why it smoked? Turbo issue?
Oil in cylinders?
Worth taking the turbo pipes off to investigate if oil inside.
Post #648825 Mon Jul 14 2025 5:17pm
dafrog
I'll be doing that. Removing pipes, turbo... but I'd like to refurbish it properly when the engine's off, which I have to do now, but living such a long way away and having not much TDV6 around, if the innards are the same, I'd like to use them.
Post #648826 Mon Jul 14 2025 5:50pm
