![]() | Home > Technical > ACE warning light and pogo’ing suspension |
Fault codes? |
| InitialB Member Since: 30 Jun 2025 Location: Edinburgh Posts: 6
Here’s the info I pulled off the computer….
Obviously due to my exceptional computer skills I’ve managed to put the pictures in the wrong place but the info is there 😂 |
Cross articulation is a ride height issue, be it a faulty sensor, wiring issue or poor calibration |
Lovely…doesn’t sound too disastrous. As it’s an issue that’s presented “out the blue” would the ride height sensors be the best place to start? Especially as that’s probably the cheapest option. |
I’ve been out playing with the air suspension settings and noticed the following which may be relevant….
| Meshan Member Since: 19 Oct 2024 Location: Northampton Posts: 101
I replaced my pump and the "raising slowly" stopped. L320 Range Rover Sport 2008
Raising slowly message should only appear when the air reservoir is exhausted of its storage of air.
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159
The extended mode when lowering can be an indicator of an exhaust valve issue, can't it? Thinks it's not lowering because it's on an obstacle when really it's because the system won't vent because of the valve sticking. 2012 SDV6 - it's missing a couple of cylinders
Yes, it would, and does, but it also wouldn't cause a cross articulation issue.
Ah, missed the cross articulation error. |
| All times are GMT |
