Home > Technical > EGR on 2007 Range Rover Sport
Benji
Is it essential that a faulty EGR is replaced quickly? I believe it will affect the emissions and could fail an MOT?
Is that correct and if so any idea what a Landrover specialist should charge?
Post #648561 Wed Jun 25 2025 5:03pm
If it’s stuck open it could melt the inlet manifold. Further cost.
Post #648564 Wed Jun 25 2025 6:02pm
Benji
Thanks Andy,
I assume I should get the EGR replaced then ASAP?
Any idea what the average cost should be for a Landrover specialist to do the job?
Post #648565 Wed Jun 25 2025 7:01pm
Benji
Is it difficult to replace the EGR valve, as i believe it's got to be done as my vehicle could fail the MOT on poor emissions if its left and cause damage to the engine?
Any help would be appreciated
Post #648571 Wed Jun 25 2025 9:46pm
A light on the dash will cause an MOT failure.
Probably won’t be an emissions failure though
A cheap fix is to blank them, but that will likely still cause a light on the dash.
Not difficult to replace. I would guess £500 total, but I don’t know
Post #648572 Wed Jun 25 2025 9:55pm
Benji
That's the problem, I've got an engine management light which comes on intermittently then goes out and the diagnostic test has flagged up a faulty EGR. I don't think I have a choice but to get it changed?. I understand if I don't change the EGR it could cause damage to the engine etc?
Post #648574 Wed Jun 25 2025 10:09pm
