![]() | Home > Faults & Fixes > Arrrgggghhh!!!! Now ACE valve seals leaking |
Heheshamon Member Since: 31 May 2023 Location: Leicester Posts: 36 ![]() ![]() |
I'm not getting too excited but I did the plate up extra tight yesterday and today it has seemed to have stopped leaking all dry i hope so anyway.
So the leak is back from the rear ace valve seals can anyone answer my first post in regards to pulling the pipes from the block. |
daxmatt Member Since: 16 Aug 2014 Location: kent Posts: 219 ![]() |
Its probably a new or 2nd hand Ace unit, unless you change it yourself its gonna be expensive.
Thanks for the reply yeah I'll be doing the work myself always done work on my cars don't see the point in paying hundreds of pounds for someone else to do work that can be done by a competent person.
Ok so attempted to fit new seals today but didn't work its not dripping anymore but its still weeping, it looks like whoever fitted the new pipes did replace the seals but didn't take any care in the process and there is a lot of scoring in the block.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4519 ![]() ![]() ![]() |
The blocks are horrendous for corrosion in by the seals
A4j1s0 Member Since: 11 May 2022 Location: Gloucestershire Posts: 34 ![]() ![]() ![]() |
I am in the same position as you
As per a few comments flying around this among many things was a major flaw by JLR R&D, for an all terrain vehicle with a major suspension component being fitted to the chassis with steel pipes makes me think it was made to fail.
LET THE FUN BEGIN!!!
Cymru001 Member Since: 07 Aug 2019 Location: Newport, South Wales Posts: 33 ![]() ![]() ![]() |
Hi pal if its anything like mine you will not get the seals to seat again the only option is to take the valve off the car strip it down and get it modified to take hydaulic hoses.
Thanks for the swift reply. I've already bought the new front pipes (£708!!!) but saw one of the seals was damaged. Hoping pressing in a new one before inserting the new pipes will fix the problem. I'm also going with the original seals for the other three holes so wish me luck. |
If you already have the seals you can try but if the aluminium has corroded then it won't seal.
